997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
Glenn99C2
PostPosted: Mon Nov 11, 2019 9:58 pm    Post subject: 996 Things to check change whilst the engine is out? Reply with quote
I had the engine out on my 996 C2 Tip cabrio (1999 72k miles) when I purchased it at a specialist to get the IMS, RMS and Oil separator replaced. Unfortunately 14months (1200miles) down the line the engine is out again to deal with a water leak from one of the plastic pipes on the separator which has cracked. Is there any other parts/items that can only be replaced while the engine is out that are common problems that I should consider replacing?
Glenn
Current
1999 Porsche 996 C2 Cabriolet
2013 Audi TT Amplified Black Edition
Previous
1990 964 C2 Rubystone RS look
1975 911S
PostPosted: Mon Nov 11, 2019 10:07 pm    Post subject: Reply with quote
Rear brake lines are a must.
fot0
PostPosted: Mon Nov 11, 2019 10:21 pm    Post subject: Reply with quote
General condition of underbody for rust & corrosion - treat as necessary
Pickse
PostPosted: Mon Nov 11, 2019 10:38 pm    Post subject: Reply with quote
Mine's a Turbo so I had a few different problems to address which you won't but what I think might be common would be aluminium coolant pipes which look ok but were corroded where they sit in the retaining clips. And not just engine bay brake pipes but underbody brake line front and rear, on mine I'd had advisories on MOT for a couple of years.
I also had a replacement coolant expansion tank. Apparently they do crack and are difficult to replace with the engine in place (on a Turbo anyway).
Also on the Tip box there are a couple of external oil lines which needed replacement. 2003 with around 85k miles at the time.
Lastly and while not related to engine out would be the steering rack pipes, mine were pretty nasty.
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
steve r
PostPosted: Tue Nov 12, 2019 10:42 am    Post subject: Reply with quote
When mine was out the brake pipes, aluminium coolant pipes, power steering pipes and coolant tank were all changed.
The engine came out for the brake pipes but the others showed the signs of age / wear so i and them all done to save removing the again in the near future.
40th Anniversary
PostPosted: Tue Nov 12, 2019 8:32 pm    Post subject: Reply with quote
Everything in the image below needs checking or replacing .. i would also say have a good look at the wiring grommet o/s/r as the bodywork often corrodes badly at this point .
 Filesize:  422.9 KB
 Viewed:  780 Time(s)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Nov 12, 2019 8:35 pm    Post subject: Reply with quote
The brake pipe can be seen running across above the two large aluminium pioes in the picture. I would also check the fuel rails and clutch slave cylinder.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Nov 12, 2019 9:02 pm    Post subject: Reply with quote
I had my engine dropped a while ago to fix an AOS. The Indy did say he’d check for any other issues, but he didn’t report anything and I didn’t get a chance to go and have a look.
It will be annoying if something needs doing now...
Out if interest is there a better spec AOS than the failure-prone standard one?
Mac996t
PostPosted: Tue Nov 12, 2019 9:33 pm    Post subject: Reply with quote
Change M96.01 for a M96.70, only joking!!!
Water pump, if it’s the original there’s probably not much life left in it.
Oil pressure sender if it’s looking corroded, and check the spade connectors to it on the end of the loom as it’s very common for them to corrode. Quite why the oil sender doesn’t have a proper waterproof connector I don’t know!
Glenn99C2
PostPosted: Mon Nov 18, 2019 5:34 pm    Post subject: Reply with quote
The AOS that is being replaced is a new one that I put on when I bought the car 1year 1400miles ago......I noticed the leak within a month, had it checked twice over the year before taking the engine out. From description it sounds like the small water pipe was fractured during the refit Sad
Current
Previous
1975 911S
