997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
Lukec4s
PostPosted: Sun Nov 10, 2019 7:33 pm    Post subject: Switchable exhaust Reply with quote
Hi all
I’m looking at a switchable exhaust and have done a bit of reading. If anyone has an aftermarket one where did you connect the power wire ? The obv place would be the battery / positive terminal clamp in engine area but I beleice it’s meant to Ben a switched live not permanent live.
Ferrari 360
996 c4s
Clio 182 track car - it’s fun
cobrars
PostPosted: Mon Nov 11, 2019 6:59 pm    Post subject: Reply with quote
Hi there,
I just picked up a feed from the cigarette lighter for the switch, then ran a 5 core cable from the switch up inside the O/S rear door card and through the rubber grommet into the engine bay where i used the air pump mounts to fix a waterproof box for the connections/solenoid. Didn't need all 5 cores, its just all i had to hand at the time.
I seem to have lost some pics of when i done it. It's pretty easy to do though.
Good luck if you go ahead thumbsup
Current : Porsche 911 996 C2 Manual With Full Hartech Engine & Gearbox Rebuild
Current : VW Golf 25th Anniversary No 1398
Previous : TVR Cerbera 4.5
Car Thread - http://911uk.com/viewtopic.php?t=118834&highlight=
Lukec4s
PostPosted: Wed Nov 13, 2019 8:39 am    Post subject: Reply with quote
Thank you. Very detailed cheers
Ferrari 360
996 c4s
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Nov 13, 2019 9:20 am    Post subject: Reply with quote
That latching relay is massively cheaper than using the proper Porsche part, but you lose the part which everybody wants to disable anyway Smile
I think I'll fit one of those in my car as I don't have the Porsche part at the moment.
