997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
g911omr
PostPosted: Thu Nov 14, 2019 9:55 am    Post subject: Reply with quote
I looked at a C2.2 with aerokit a few years back that looked like it was going rotten underneath. Mostly around where the covers are attached to the sills.
The trouble is that once it starts the rot just spreads out.
TurboRob
PostPosted: Thu Nov 14, 2019 11:43 am    Post subject: Reply with quote
Interesting thread and great work Ned - love seeing proper fabricating skills.
When I was buying a 996 12 months ago I generally found the ones without aerokits were less rusty.
996.2 C2
NedHan79
PostPosted: Thu Nov 14, 2019 2:03 pm    Post subject: Reply with quote
Thanks guys. I made the arches from scratch. I basically made a template from cardboard, them out of 1/2” ply (an old school desk). Cut steel to size, screw to the template and then basically hammer the edge over. I used a plastic bossing mallet and plannishing hammer and dolly’s. Takes a while but patience is key for a better finish.
I joddled the step in to give me room to move the arch to get the best fit. It’d be very hard to get the edges right to but weld. Also this is my first go at this so I wasn’t sure. I plug welded all holes and seem welded the complete arch so should be water tight. Everything has weld through primer so even if water did get in, it’s at least painted. And cavity wax too of course.
The inner arch (tub) was also cut out and made. This was not easy on the floor. Everything would have been easier on a ramp.
I’ll see what pictures I can dig out. Like I said it’s a bit of a faff to get them on here
#modified996mk1
NedHan79
PostPosted: Thu Nov 14, 2019 2:12 pm    Post subject: Reply with quote
Template for arch
#modified996mk1
 Filesize:  464.06 KB
 Viewed:  369 Time(s)
NedHan79
PostPosted: Thu Nov 14, 2019 2:13 pm    Post subject: Reply with quote
Arch seem welded
#modified996mk1
 Filesize:  918.69 KB
 Viewed:  367 Time(s)
NedHan79
PostPosted: Thu Nov 14, 2019 2:14 pm    Post subject: Reply with quote
Inner arch/tub. Not easy getting a decent photo due to space
#modified996mk1
 Filesize:  516.12 KB
 Viewed:  364 Time(s)
NedHan79
PostPosted: Thu Nov 14, 2019 2:15 pm    Post subject: Reply with quote
Rear of arches rough on both sides
#modified996mk1
 Filesize:  1.2 MB
 Viewed:  359 Time(s)
NedHan79
PostPosted: Thu Nov 14, 2019 2:16 pm    Post subject: Reply with quote
Rear of quarter panel cut out
#modified996mk1
 Filesize:  917.67 KB
 Viewed:  357 Time(s)
NedHan79
PostPosted: Thu Nov 14, 2019 2:18 pm    Post subject: Reply with quote
New inner and outer pieces fitted and joined. Everything round the arches have yet to be properly buffed back and filled but have been primed to keep them good
#modified996mk1
 Filesize:  1.31 MB
 Viewed:  355 Time(s)
rgracin
PostPosted: Thu Nov 14, 2019 6:07 pm    Post subject: Reply with quote
Thanks for those. Looks really good.
I need similar doing to one of the rear arches on mine. Did a bodywork restoration evening course a couple of years ago, but still haven't put it into practice. Not sure if I've got the balls for the this to be the first job!
2003 Manual 996 Turbo
2000 986 Boxster S
NedHan79
PostPosted: Thu Nov 14, 2019 6:41 pm    Post subject: Reply with quote
I’ll admit I was very nervous (for want of a better expression.lol) about cutting it all out. I was bricking it about cutting the arches out but found that it was a lot easier making them than the likes of the front of the sills.
A 911’s not the cheapest yoke to be learning on Floor
#modified996mk1
Goto page Previous  1, 2
Page 2 of 2
