997 : 2004- 64
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
tuscanracer
PostPosted: Sat Nov 09, 2019 7:44 am    Post subject: After a hardtop or good outdoor cover! Reply with quote
As per the title im looking for either a hardtop or good outside cover to get my c4s cab through the winter? Many thanks
grbspeedster
PostPosted: Sat Nov 09, 2019 8:25 am    Post subject: Reply with quote
PM sent
Meant to say friends hardtop has full fitting kit,covers and wrench to fit
Geoff
996 X50 turbo cab
grbspeedster
PostPosted: Sat Nov 09, 2019 8:27 am    Post subject: Reply with quote
His name is Alan, sorry missed off PM frustrated
Geoff
996 X50 turbo cab
PostPosted: Sat Nov 09, 2019 4:55 pm    Post subject: Reply with quote
The hardtop does more damage to the car than winter does.
tuscanracer
PostPosted: Sat Nov 09, 2019 6:54 pm    Post subject: Reply with quote
Hi thanks for the reply, could you elaborate for me thanks
PostPosted: Sat Nov 09, 2019 7:13 pm    Post subject: Reply with quote
Mine ended up marking the soft top as the parcel shelf of the hardtop is clamped down on the folded soft top underneath it. You will probably also get some mould possibly growing on the soft top if its not 100% dry when you fold it down before fitting the hard top. You can easily scuff the trim around the location holes behind the rear seats when installing and it also rubs your paintwork off at the top of the a pillar and along the top of the front window frame.
Unless you get it fit absolutely perfect it rattles and bangs whilst you're driving. Other than that.......it's great.
