997 : 2004- 69
Boxster : 1997- 31
acer54
PostPosted: Fri Nov 08, 2019 2:02 pm    Post subject: 4 wheel drive system fault Reply with quote
I used to get this fault if the car had been stood for a week or so, once the car had been used for a few miles if you switched the car off and back on again the fault disappeared.
I found as time went on it was happening more often and I decided to change the Battery, once the battery was changed I had no more issues during the warm Summer months.
Now that we are experiencing colder temperatures overnight every time I use the car I get the fault again and after a few short miles if I stop and start the car again it disappears until the next start the following day after been parked overnight.
Anybody got any experience of this themselves and if so what was the fix?
2005 Porsche Cayenne V6 3.2 Litre
PostPosted: Fri Nov 08, 2019 8:28 pm    Post subject: Reply with quote
Do you have any kind of tester that might be able to check fault codes and then post ?
without any code then any answer is a stab in the dark i'm afraid .
