997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Cannop
PostPosted: Thu Nov 07, 2019 10:23 am    Post subject: Short shift shenanigans Reply with quote
I've had a short shifter fitted to my C2S for almost as long as I've had the car, fitting it was one of the first jobs I carried out when I bought the car.
It's one of the generic Chinese manufactured ones and it improves the feel of the gear changes immensely, however when I fitted it I did notice the ball for the left to right action of the lever dispenses with the engineered socket insert that the original uses. As the ball is larger it fills the square hole left by the omitted original insert and this has always struck me as not a very well engineered solution as the ball is only touching the square socket in four locations. I don't know whether it's the placebo effect or not but I've always felt the left to right action as being a little compromised compared with the original shifter albeit with a shorter throw.
Anyway the opportunity to buy a new genuine Porsche short shift kit at less than a third of retail presented itself so I thought it would be a worthwhile exercise to buy it and get it fitted.
Below you can see the kit I had fitted, the socket that niggled me is the one on the left in the white nylon lever but the metal housings for the left right pivots are also also a very bulky solution!
Here it is with all the covers removed.
Side by side with the new kit you can see the differences, the throw (the fulcrum points) are virtually identical to the Porsche short shift original.
Here you can see the difference in the fulcrum point compared to the original 'long shift' lever, it doesn't look like much but makes a huge difference to the action.
Here's the new kit going in.
One point that may help anyone doing this job is clarification of the disconnection of the gear lever gaiter from the shifter knob itself. The online guides I've read tell you to grip the piece under the gear knob and twist to allow you to pull the knob off but dont seem to make clear what the piece looks like or what direction to twist or how far!
The section to turn is connected to the gaiter and looks like this in situ.
Looking from above it needs to be rotated through 90 degrees clockwise to release the knob itself.
With the knob removed you can see how it works in these photos. When locked it looks like this:
And when rotated through 90 degrees it looks like this, the two cutouts align with those in the knob itself to allow the clearance for removal.
Remember when refitting it it's 90 degrees anticlockwise to lock it!
Anyway, the OEM kit is now fitted and as I've already said it's probably the placebo effect but the change does seem more precise with less side to side play!
If anyone needs a Chinese short shift kit drop me a pm! Thumb
Full fat Hartech'd C2S Manual
PostPosted: Thu Nov 07, 2019 11:32 am    Post subject: Reply with quote
You should've bought one of mine. Wink
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Nov 07, 2019 12:26 pm    Post subject: Reply with quote
to be fair your modified version doesnt change anything that the OP was concerned about and is the same as the bay kits for that bit (which I think is 100% placebo... Floor )
My 997.1 C2 ownership thread: http://911uk.com/viewtopic.php?t=134228
PostPosted: Thu Nov 07, 2019 12:39 pm    Post subject: Reply with quote
Left to right throw is identical on travel on all kits, only up/down is altered.
My kit has more superior bearings for this appilcation than anything else including Porsche.
Cannop
PostPosted: Thu Nov 07, 2019 12:50 pm    Post subject: Reply with quote
One thing to note is I've now removed the Chinese short shift lever from the OEM carrier to inspect the square socket, which as you recall is the part that has the ball operating on it. There are definitely indentions in the four areas (top, bottom, left and right) where the ball contacts it, which can only be due to wear caused by the ball over the last couple of years.
This now leads me to believe the more positive feel is probably something more than just the placebo effect!
Cannop
PostPosted: Thu Nov 07, 2019 12:52 pm    Post subject: Reply with quote
One of your what Alex, short shift kits? I would have done had I known you made them!
Thefinn
PostPosted: Thu Nov 07, 2019 1:16 pm    Post subject: Reply with quote
I have both a Chinese SS and OEM in different cars and I find the Chinese ones to has a too short throw making them a bit too notchy, especially when cold, where as the OEM being slightly longer feels just right. You can improve the OEM one though by adding some Phoenix Engineering billet bushes to reduce the slop of the plastic they come with.
997.1 C4S CAB
Hertsdriver
PostPosted: Thu Nov 07, 2019 1:27 pm    Post subject: Reply with quote
He doesn't make them, he modifies the short shifter you already have (chinese one) to remove poor production tolerances and fit decent bushes getting rid of the plastic ones that the kit comes with. Its a great idea, you should check his thread:
http://911uk.com/viewtopic.php?t=127355&postdays=0&postorder=asc&start=0
BUT It doesn't address the way the kit locks into the factory plastic 'block' on the left which was the reason you changed to the factory short shift. Thumb
Cannop
PostPosted: Thu Nov 07, 2019 1:58 pm    Post subject: Reply with quote
Ah I see, thanks for the link. It's definitely a better solution than the standard Chinese and OEM bushings!
As you rightly point out though it doesn't address the main reason I replaced mine, namely the lack of a proper ball and socket joint which the OEM has.
MarkGolf
PostPosted: Thu Nov 07, 2019 4:25 pm    Post subject: Reply with quote
Ahh this is the issue I have with my china shifters!! Loosing the square socket joint thing results in side to side play as the ball bit doesn't sit in the white thingy perfectly!! I was going to wrap tape around mine but decided not to in the end. I would LOVE to lose this side to side play as otherwise, the shifter does the job for me. It's the same in my 997 and 986.
SAVE US ALEX!!! Make something to sort this!! worship
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
PostPosted: Thu Nov 07, 2019 4:40 pm    Post subject: Reply with quote
I have thought about it but on mine there is virtually no play in that area so I scrapped it off.
If I were you I'd wrap some plumbers PTFE tape round it to take the play out........it is the slipperiest stuff known to man.
PostPosted: Thu Nov 07, 2019 8:17 pm    Post subject: Reply with quote
You twist the base " lock device " then you pull the gear knob upwards .. don't have your face over it as sometimes you have to pull pretty hard to get the gear knob off ...
I have seen a mechanic punch himself in the face whilst doing this !!!
Indy Mechanic .
Cannop
PostPosted: Fri Nov 08, 2019 11:24 am    Post subject: Reply with quote
Mine wouldn't budge so I used a thick plastic spudger with a crowbar foot end, placed it on it's side around the metal column of the gear selector as a spacer then used a metal trim remover in between the spudger and the bottom of the gear knob/boot and levered upwards. It came away in a nice controlled fashion.
Cheib
PostPosted: Sat Nov 09, 2019 6:12 pm    Post subject: Reply with quote
Do you have a link for these bushes ?
997 GTS Manual
Cayenne S Diesel
Ruby Star 718 Boxster - Mrs Cheib's car
Lava Orange 991.2 GT3 Manual
Sport Classic Grey Macan Turbo PP
PostPosted: Sat Nov 09, 2019 7:21 pm    Post subject: Reply with quote
That's a pretty good idea and not something i had thought of .. i remove a lot of center consoles at work and often leave the knob and leather base attached and feed it through the consol .. about 3 last week due to the very wet weather and water ingress on cars .
I'll be giving your method a go next time Thumb
You Can teach an old dog new tricks you Know Very Happy
Indy Mechanic .
peterg1955
PostPosted: Sat Nov 09, 2019 10:01 pm    Post subject: Reply with quote
https://phenixengineering.com/shop/porsche-997-gt3-style-billet-shift-bushing-kit/
2002 996 C2 black/black with aerokit and M030 - soon to be a 3.9 Hartech
RXP.
PostPosted: Sun Nov 10, 2019 8:20 am    Post subject: Reply with quote
Such a great thread OP.
Can i ask how long did this take? I have to remove the OEM SSK and fit a different shifter.
Cannop
PostPosted: Sun Nov 10, 2019 3:26 pm    Post subject: Reply with quote
Thanks RXP! Thumb
The first time I did the job a couple of years ago it took about three hours from start to finish, mainly because I was approaching everything very cautiously so's not to snap any retaining clips or mark anything. Also the gear shift cage has to be stripped to fit the Chinese short shift lever.
Replacing the Chinese one with the genuine Porsche short shifter took about an hour simply because I'd done the job before and didn't have to strip the gear shift cage.
