997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
Lee997
PostPosted: Thu Nov 07, 2019 12:38 am    Post subject: Fault codes Reply with quote
Had access to a Launch diagnostic tool today, so seemed rude not to scan my 2005 997.1 C5.
Got following codes, not concerned about door mirror and as far as I’m aware I don’t have fog lamps ?
Number plate light works just fine although reporting an error, previous owner changed rear light clusters, front repeaters and rear number plate lights to leds? ( not sure if that has anything to do with it?)
But would like some ideas on the other faults?
 Filesize:  424.15 KB
 Viewed:  677 Time(s)
PostPosted: Thu Nov 07, 2019 8:24 pm    Post subject: Reply with quote
Ok then ..
Communication and voltage faults .. you have had a flat battery at some point or a low charged battery .. perfectly normal and will clear after deleting the codes .. if not then you have a problem .. i doubt it though .
Mirror adjustment .. if they work up/down and side to side then there is no issue .. possible battery .. clear the codes and recheck .
Bonnet lock .. again battery i suspect or a sticking switch on the lock .
Fog lights .. either a fault or the lights have been disconnected in the past and ignition has been turned on .. delete codes , turn on fog lights and check if they work and if a code is entered again .
term 50 .. battery low .
Number plate light .. bulb has blown .. probably replaced and this is an old code .. turn lights on and check if they are both working .
job done Smile
Indy Mechanic .
