997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
pauluk996turbo
2003 Porsche 996 Turbo
PostPosted: Mon Nov 04, 2019 9:58 pm    Post subject: who is running a solid flywheel on a turbo Reply with quote
hi all i had a lightened ( solid ) flywheel fitted to my 996 turbo last year and love the way it drives engine feels much more like what i would imagine a 911 engine to be like but ...
i do have a problem with the engine stalling seems every time i come to a set of traffic lights it just wants to stall does anyone actually run one in a daily ? as i would like to start using the car more often
i was thinking of getting the idle increased slightly but not sure if this would actually help Dont know
any help would be appreciated
thanks
mk2 996 turbo
pic because why not
 Filesize:  104.1 KB
 Viewed:  1061 Time(s)
Martin996RSR
PostPosted: Tue Nov 05, 2019 12:07 pm    Post subject: Reply with quote
When I bought my 996 c2 I was told it had a lightweight flywheel and that this was why it was so easy to stall when parking etc. It turned out it was a vacuum leak that was causing it to stall so easily, and when I changed the clutch & flywheel, I found it was a normal dual mass one.
I think you may be able to determine if you have a vaccuum leak by checking your fuel trim with a computer, but I'm not certain. Hopefully Demort will be along soon and will be able to help you.
pauluk996turbo
PostPosted: Tue Nov 05, 2019 4:18 pm    Post subject: Reply with quote
thanks for the reply but i do defiantly have a solid flywheel as i has it fitted when i had the clutch changed
in terms of vacuum leak may be worth a check as it does stall very easy and maybe the mechanic broke something when fitting the clutch Dont know
mk2 996 turbo
Martin996RSR
PostPosted: Tue Nov 05, 2019 4:43 pm    Post subject: Reply with quote
Yep, I wasn't suggesting you don't have a LWFW, just that you might want to investigate the possibility of a vacuum leak. Are you getting all the boost that you should be? A vacuum leak becomes a boost leak under boost remember.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Nov 05, 2019 6:23 pm    Post subject: Reply with quote
I had the tickover speed raised and a small hole drilled in the throttle butterfly. Depending on the tune it seems that the revs can fall so quickly that the idle speed control is too slow to react and can't catch it before it stalls. Once sorted mine was 100% stall free.
Billy Bumpsteer
PostPosted: Tue Nov 05, 2019 7:35 pm    Post subject: Reply with quote
It shouldn't stall, and if you have one its obvious if you have driven Porsche with them before.
pauluk996turbo
PostPosted: Tue Nov 05, 2019 9:20 pm    Post subject: Reply with quote
yes boosting very well around 0.8-0.9 boost might have to pay desgin 911 a visit as its one of there flywheels and just to see if they can confirm its acting as it should
mk2 996 turbo
pauluk996turbo
PostPosted: Tue Nov 05, 2019 9:23 pm    Post subject: Reply with quote
thanks for the reply ! may i ask who done it for you ? it currently has a desgin 911 map on the car if that helps at all Dont know Grin
mk2 996 turbo
996ttalot
Approved Trader
PostPosted: Wed Nov 06, 2019 7:41 am    Post subject: Reply with quote
The common one is as you approach the traffic lights you put it into neutral -
Car will then stall as the flywheel will not be heavy enough to keep the engine going - just in case this is how you are driving.
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
MisterCorn
PostPosted: Wed Nov 06, 2019 8:19 am    Post subject: Reply with quote
pauluk996turbo wrote:
My car is looked after by Matt at Fearnsport. The other option is to keep your foot very slightly on the throttle as the revs drop, but that isn't anywhere near as easy.
pauluk996turbo
PostPosted: Wed Nov 06, 2019 3:50 pm    Post subject: Reply with quote
[quote="MisterCorn"]
i have tried that and cannot do it Floor but i called fearnsport this morning a seem to be great guys they have advised me about drilling the throttle body valve which i will do when the car returns and ive also arrange to take my car up to them for a complete once over and a suspension setup
mk2 996 turbo
