997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
Stoddy
PostPosted: Mon Nov 04, 2019 9:35 pm    Post subject: Strange starter motor sound when hot. Reply with quote
I noticed during my lovely Sunday drive, that on re starting the car after a short stop, the starter motor sounded slightly odd. It’s a sort of choking sound when the car is hot.
When it’s cold, no problem, it’s just when it’s hot.
Is the starter about to give up? Or is it maybe an earthing issue?
Any thoughts gratefully received!
Stoddy Question
The world is flat
2005 997.1 3.6 (Rufus -THE DUKE)
2002 996 3.6 C2 (Henry) For sale.
Restoring THE COLONEL, 1973 914.
X 944 S2 Cab (Miller)
X 3.2 Carrera (Gordon)
X 3.4 Cayman (George)
maldren
PostPosted: Tue Nov 05, 2019 5:29 pm    Post subject: Reply with quote
Alex took his apart and re-greased the rear bearing to stop a squeal that mine had too.
I took mine apart and found that the rear bearing grease had dried up. I took the motor apart and also re-greased the gearing but decided that I didn't want to have to do it again so I fitted a new motor (courtesy Eurocarparts) for about £130 exchange.
It's not too bad a job as long as you have a set of wobble bars as socket set extensions.
Mike
Stoddy
PostPosted: Tue Nov 05, 2019 6:09 pm    Post subject: Reply with quote
Oh ok, yeah, I guess the sound could be a bearing? Well I reckon for that price, I’ll exchange it.
What’s a wobble bar by the way Mike?
Thanks for the info!
Rich.
The world is flat
fot0
PostPosted: Tue Nov 05, 2019 9:26 pm    Post subject: Reply with quote
"choking" as in lethargic or difficult to start when hot? More likely to be positive cable running from jump post connecting to starter and alternator. The cable eventually breaks down with age and heat.
Stoddy
PostPosted: Tue Nov 05, 2019 10:39 pm    Post subject: Reply with quote
Ooh, that sounds bang on!
Where’s the jump post??
The world is flat
maldren
PostPosted: Wed Nov 06, 2019 8:19 am    Post subject: Reply with quote
These are what I bought:
The extensions have a curved profile that allows them to be used at an angle, more easy to control than UJs and ideal for working around Porsche (and other) engine bays.
Mike
 Filesize:  46.84 KB
 Viewed:  1423 Time(s)
Stoddy
PostPosted: Wed Nov 06, 2019 9:49 am    Post subject: Reply with quote
Brilliant thanks!
Rich.
The world is flat
fot0
PostPosted: Wed Nov 06, 2019 9:33 pm    Post subject: Reply with quote
As you look at engine - top right. Plastic rectangle box that opens to reveal the +jump post. This is where the starter cable terminates.
Stoddy
PostPosted: Wed Nov 06, 2019 9:36 pm    Post subject: Reply with quote
Great stuff, I’ll try and look tomorrow.
Cheers!
Rich. 👍👍🤘
The world is flat
Stoddy
PostPosted: Sun Nov 10, 2019 2:04 pm    Post subject: Reply with quote
Ok, can’t see any sign of cable breaking down on the jump post, I guess it’s more likely that it’s down near the motor it’s self?
Rich.
The world is flat
fot0
PostPosted: Sun Nov 10, 2019 7:57 pm    Post subject: Reply with quote
It won't be visibly damaged, but sounds similar to an issue I had. I suspect where the copper cable is joined/crimped at the terminals it will eventually lose conductivity with constant heating and cooling. An indie should be able to test for you with a multimeter.
Stoddy
PostPosted: Sun Nov 10, 2019 11:01 pm    Post subject: Reply with quote
Ok cheers. I’ll have to get it sorted as it very nearly didn’t re start today when hot after I’d stopped.
In Manchester now.
Stoddy
The world is flat
kurlykris
PostPosted: Sun Nov 10, 2019 11:24 pm    Post subject: Reply with quote
If I was remaking the joint/crimp lug or replacing the cable ( as an electrician by trade ) I would tin ( solder) the stripped cable end, before crimping on the new lug, then heat the new joint/lug up with a blowtorch and run some more solder into the joint, that way it will never happen again in future Thumb
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
77szymon
2003 Porsche 996 Carrera 4S
PostPosted: Fri Nov 15, 2019 3:32 pm    Post subject: Reply with quote
I'm not sure if you have same problem as mine was but..... mine hot starting end up with £4000 bill if your car is manual take out air box and spin engine any resistance in the same place NOT GOOD.
If you need any more info ask, I'm from Rochdale if not far you can come by just send me PM.
2003 Porsche 911 996 c4s
1988 BMW 635csi Highline - waiting for full restoration
1999 BMW e36 328i Cabrio - still not finished project.....
2011 Mercedes S350L - SOLD
2004 Audi a2 1.4 tdi - I can't stress enough how good these cars are
̶2̶0̶1̶2̶ ̶M̶e̶r̶c̶e̶d̶e̶s̶ ̶C̶2̶2̶0̶ ̶c̶d̶i̶ ̶E̶s̶t̶a̶t̶e̶ ̶A̶M̶G̶ ̶S̶p̶o̶r̶t̶ ̶P̶l̶u̶s̶ ̶P̶a̶c̶k̶ ̶-̶ ̶w̶i̶f̶e̶
Stoddy
PostPosted: Sat Nov 16, 2019 1:27 pm    Post subject: Reply with quote
Sent you a pm mate.
The world is flat
77szymon
PostPosted: Sat Nov 16, 2019 1:38 pm    Post subject: Reply with quote
I don't have any new messages......
jezgreen911
PostPosted: Sat Nov 16, 2019 2:43 pm    Post subject: Reply with quote
Can you share your experience for the greater good?
2003 996 C2
77szymon
PostPosted: Sat Nov 16, 2019 5:56 pm    Post subject: Reply with quote
sure...
my problem strat something in 2017 with hot engine start, I did all starter/alternator/battery/connections etc. then I took engine off car for more work put it back together and "hot" problem did not disappear, only on hot engine cold was ok, so I took my car on 1000 mile trip and I think that was too much for it as "hot" problem become also "cold" start problem, so on July engine completely seized after hard pushing day before, what I do connecting with it and I could be wrong but if you try spin engine with spanner mine engine was half way easy and another half difficult every time same place so my conclusion is this depends in what place engine stops either it is easy to start or difficult and it shows that engine is at fault in my case crank bearings was shot dead and I was LUCKY it did not start only seized.
This theory could be confirmed by more professional then me guys on this lovely forum.
my short story:
911uk.com/viewtopic.php?t=135923&highlight=
Stoddy
PostPosted: Sat Nov 16, 2019 6:07 pm    Post subject: Reply with quote
Cool man, that’s really useful info. Why don’t you just post those reply’s on the forum, that’s what it’s there for I guess!
I’m in Manchester till December working, I’ll try and hook up at some point, though I’m home most weekends.
Rich.
The world is flat
