997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
PostPosted: Mon Nov 04, 2019 3:15 pm    Post subject: Oil Level Reset Help !!!!!!!! ----------------- Reply with quote
Hi all, i carried out an oil change over the weekend and filled up with 7 liters of oil to be carefull not over filling, to reset the oil level counter ibfollowed instruction on the attached picture below, and shows me 1 bar on the oil level flashing allthough theres 7 liters of oil.
Am i doing something wrong? Is it correct with the information below on resetting the oil Level?
J
 Filesize:  1.41 MB
 Viewed:  1532 Time(s)
Porschekit
PostPosted: Mon Nov 04, 2019 4:45 pm    Post subject: Reply with quote
I think your answer is in point 5 of the picture.
The 7 litres will have filled the majority of the oil sump and it now needs gradually topping up to full, by 0.4 litre increments.
The gauge actually only shows the "top up" area not the complete oil tank.
So keep adding oil in batches until the gauge shows it is climbing "up the neck" so to speak....
997.1 C4S Meteor Grey Metalic
-- 997 --
PostPosted: Mon Nov 04, 2019 5:42 pm    Post subject: Reply with quote
Hi, ok so theres 7 liters of oil already in the engine, the oil level bar shows up on one bar and flashes, at least it should show just over half way then pour oil increments untill it reaches to the full mark !!
Cheers...
J
PostPosted: Mon Nov 04, 2019 6:25 pm    Post subject: Reply with quote
Follow steps 4 and 5 adding about 0.2 litres at a time.
Be careful not to overfill. Leaving it one bar from the max level will be fine.
-- 997 --
PostPosted: Mon Nov 04, 2019 7:20 pm    Post subject: Reply with quote
T8, would i need to do it from the start then, run engine to temp the follow the steps ? Or just from 4 to 5?
J
Jam911
PostPosted: Mon Nov 04, 2019 7:26 pm    Post subject: Reply with quote
It should take at least 8.5 lt in total
Current '07 997 C4S
Ex '99 2.5 Boxster
GlenB
PostPosted: Mon Nov 04, 2019 10:28 pm    Post subject: Reply with quote
I knew there was no dipstick and you had to use the display, but what an incredibly dick way of having to do things. No wonder Porsche charged me so much for an oil and filter change hahaha.
Seriously, what was wrong with the dipstick invention?
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Mon Nov 04, 2019 11:27 pm    Post subject: Reply with quote
J
As long as your oil temp is around 90, you don’t need to mess around with 20 mins idleing each time. You have to let the electronic dipstick do its countdown. If oil is not up to temp it will tell you.
Personally I would stop at one bar under max. Monitor the level when back from a drive. Top-up if necessary. When you check the oil level, always do it with car in the same place. (I check mine a couple of times a week when I’ve parked in my garage after returning from work)
jl-c
PostPosted: Tue Nov 05, 2019 8:37 am    Post subject: Reply with quote
"Personally I would stop at one bar under max. Monitor the level when back from a drive. Top-up if necessary. When you check the oil level, always do it with car in the same place. (I check mine a couple of times a week when I’ve parked in my garage after returning from work)"
I would agree,BUT, make sure it is flat. A tilt of only a few degrees will alter the reading significantly. I too would run it 1 bar down, measured cold because hot it then reads full.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Nov 05, 2019 9:19 am    Post subject: Reply with quote
I have to agree, it is an idiotic solution to a problem that doesnt exist - a dipstick is much easier Thumb
My 997.1 C2 ownership thread: http://911uk.com/viewtopic.php?t=134228
-- 997 --
PostPosted: Tue Nov 05, 2019 11:08 am    Post subject: Reply with quote
Hi, ok this is what im getting!! Picture below, it flashes at first bar deaoite having 7 liters... at least it should show me the 7 liters mark on the level etc.. muat be doing something wring here... before oil change it gave me correct reading!!
Bloody baffled!! Confused Confused Confused Confused
Cheers..
J
 Filesize:  1.69 MB
 Viewed:  1244 Time(s)
-- 997 --
PostPosted: Tue Nov 05, 2019 11:09 am    Post subject: Reply with quote
Oops!! Duplicate post !!
Porschekit
PostPosted: Tue Nov 05, 2019 11:32 am    Post subject: Reply with quote
As above.....if you're not getting a reading and you've only put 7 litres in then keep putting oil in as 0.4 ltr increments until it starts registering up that scale....you could potentially be 1.5 litres short....
-- 997 --
PostPosted: Tue Nov 05, 2019 3:50 pm    Post subject: Reply with quote
Hi, am sure the guage can read 7 litres which above the half way line at least etc....
J
MR997
PostPosted: Tue Nov 05, 2019 6:15 pm    Post subject: Reply with quote
You are treating the gauge as though it reads the whole quantity of the engine - it doesn't
The total capacity is 8.5ltr. Add .5ltr and repeat the oil check ensuring the car is on flat level ground and see if the gauge rises by 1 bar.
robro911
PostPosted: Tue Nov 05, 2019 6:23 pm    Post subject: Reply with quote
I've just done an oil change on my C2 gen 1 today and all I can squeeze into it is 7.6 litres and yes it was completely drained and yes its on level ground !!
jl-c
PostPosted: Tue Nov 05, 2019 6:42 pm    Post subject: Reply with quote
It holds 9 litres if dry. If you only get 7.6 litres in then you have either not fully drained it or you are reading the display incorrectly or on a hill. Short of a damn big dent in your sump reducing the capacity or a faulty capacity sender, there is no other explanation. Surprised
PostPosted: Tue Nov 05, 2019 7:00 pm    Post subject: Reply with quote
The min to max lvl is 1.5 liters , if the oil is lower than this then the bottom segment will flash ... yours does so there is not enough oil in the car for it to register on the gauge .
I can say .. with 7 litres in the car it's not enough and you will have what you have already got .. it needs oil adding ( gauge will not read this low ) .
car must be run up to operating temp .. if bottom segment flashes then add 1 ltr .. recheck .. if still flashing then add 0.5 ltr and check .. you will have a reading at this point .
If the car had drained out overnight then about 9 liters is what it will take .
So a lot of this is based on just how long you drained the car for ?
Worst that can happen ... you over fill it .. if 0.5 over fill then it will still be fine ..
If you go massively over then you just have to drain some or all of it out and start again.
Can i just say .. i've drained in excess of 2 litres over filling in cars before and they drove ok .
In short i'm just repeating what has already been said ..
if you are still unsure then i'll PM you my number and i'll go through it on the phone with you Smile
Indy Mechanic .
robro911
PostPosted: Tue Nov 05, 2019 7:07 pm    Post subject: Reply with quote
jl-c wrote:
It holds 9 litres if dry. If you only get 7.6 litres in then you have either not fully drained it or you are reading the display incorrectly or on a hill. Short of a damn big dent in your sump reducing the capacity or a faulty capacity sender, there is no other explanation. :o
Interesting comment, but it was certainly drained and on level ground, however I will go back to it tomorrow and recheck the gauge. It was all so much simpler in the aircooled days with a dipstick !!
PostPosted: Tue Nov 05, 2019 7:10 pm    Post subject: Reply with quote
How long did you drain it for ?
Indy Mechanic .
