997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Geezer 911
PostPosted: Sun Nov 03, 2019 3:42 pm    Post subject: Phone book stopped syncing with PCM Reply with quote
Afternoon all
The phone book on my iPhone 10 has stopped communicating with the bluetooth on the PCM unit and no contacts are showing up.
I have been using a bovee device for the last 2 years and i have had no problems . The bovee is working fine as i can still see my music and i can still stream music from amazon music etc. The phone still connects to the bluetooth to make calls manually from my phone it just doesnt show any names of these contacts on the PCM.
Does anyone know how to solve this issue?
PostPosted: Sun Nov 03, 2019 6:32 pm    Post subject: Reply with quote
I seem to remember that on a standard system there was an issue with too many contacts and they didn't show on the PCM ..
Possible you have a large contact list ?
EDIT .. this is for pcm 3 only and bear in mind your phone is newer than the pcm.
Indy Mechanic .
 Filesize:  96.76 KB
 Viewed:  909 Time(s)
Geezer 911
PostPosted: Sun Nov 03, 2019 7:04 pm    Post subject: Reply with quote
Cheers Iain, I will try and delete some contacts and see if that solves this issue.
Geezer 911
PostPosted: Wed Nov 06, 2019 7:23 pm    Post subject: Reply with quote
Iain this worked! You are truly a legend!
PostPosted: Wed Nov 06, 2019 7:34 pm    Post subject: Reply with quote
Very Happy
Glad it worked .
Indy Mechanic .
