997 : 2004- 67
Boxster : 1997- 31
toddy2
PostPosted: Sun Nov 03, 2019 6:52 am    Post subject: 996 Ignition lock issue Reply with quote
Hi All,
Thankfully it’s been a few months since I’ve had any issues with the 996.
But recently, I have been experiencing issues with a stiff ignition lock and no lights, wipers not working. I’ve put this down to the key once turned not turning back, and when turning off and removing the key on occasions the power remains live, i.e radio stays on.
I’ve done a quick search and came across a cheap fix switch on a previous thread. I’d rather replace the ignition switch complete, does anyone know if there is an upgrade one or whether the 997 one is a better option??
Thanks in advance for any responses.
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
PostPosted: Sun Nov 03, 2019 5:31 pm    Post subject: Reply with quote
The 997 has a totally different lock so don't buy that one Smile
Cheap fix is the electrical connector .
The entire unit comes with out the barrel which in very .. er .. Very rare cases can cause a similar issue .. anyways .. just swop it over to the new lock ass .
I think you can only order the lock ass from Porsche though .
toddy2
PostPosted: Sun Nov 03, 2019 7:20 pm    Post subject: Reply with quote
Thanks as always deMort. I've ordered one of these:https://www.design911.co.uk/fu/prod140622/Ignition-starter-switch-Porsche-986-Boxster---996-2004--_2/
There's a few guides, so I'll give DIY a go. Thumb
1968 911T
2002 996 4s
1988 944 (Sold)
PostPosted: Sun Nov 03, 2019 7:28 pm    Post subject: Reply with quote
When it comes to parts then i'm never sure of anything but can i just point out .. and humbly ..
That item is listed as a 2004 and onwards ?
Your car is a 2002 ?
https://www.design911.co.uk/fu/prod833/Ingition-starter-switch-Porsche-Boxster-986-987/
To be honest .. i always get confused by < and > one is greater than and the other is less than but i never know which is which .. sigh .
toddy2
PostPosted: Sun Nov 03, 2019 8:57 pm    Post subject: Reply with quote
Thanks deMort, the part number you suggest is more appropriate 👍
1968 911T
2002 996 4s
1988 944 (Sold)
demon
PostPosted: Mon Nov 04, 2019 12:48 pm    Post subject: Reply with quote
You definitely want to fit the year appropriate switch - when I bought my car it had had a later version switch fitted, perhaps thinking it was an "upgrade" it always felt horrible turning the key and eventually it failed (largely as it chewed itself to pieces) and I discovered the mismatch - safe to say the car is far happier and the ignition action fare nicer for having the right part in it(!)
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, cargraphic backboxes, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF wing mirrors, Hartech rebuild, >245,000 miles
toddy2
PostPosted: Mon Nov 04, 2019 8:30 pm    Post subject: Reply with quote
Thanks both, swapped it for the correct year part.
Good to know the later one doesn’t work as an upgrade 👍
1968 911T
2002 996 4s
1988 944 (Sold)
