997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Gazc2
Watkins Glen
PostPosted: Wed Oct 30, 2019 11:55 am    Post subject: spire clips/speednuts source ? Reply with quote
Does anyone have a good link for decent spire nuts or speednuts whatever you call them for the undertrays/liners only about 5000 hits on ebay when you search looking for some decent ones to replace all my rusty ones.
If anyone has the right sizes for these that would help Thumb
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
andyobro
PostPosted: Wed Oct 30, 2019 12:18 pm    Post subject: Reply with quote
I looked all over when doing the underside of my 993, I could not find a good alternative supplier. I stuck to Porsche in the end, not to expensive, the right sized component, I did bath them all in XCP rust blocker to prolong their life.
Cheers Andy
993 Carrera
www.instagram.com/993andy
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Oct 30, 2019 1:26 pm    Post subject: Reply with quote
I have found that when sourcing hardware that so many online supplies turn out to be inferior quality for a relatively modest saving that buying from my OPC makes perfect sense in terms of quality, correct size, time taken to supply and durability.
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
RUDDY
PostPosted: Wed Oct 30, 2019 3:15 pm    Post subject: Reply with quote
If you look on PET most of the fasteners have the sizes listed, even the spire type screws, or check Autoatlanta’s site, simply cross these over to Ebay.
From recent experience Porsche have seriously downgraded the quality of their fasteners, if not the price, they are certainly no better than competitively priced UK supplied items, avoid the cheap Asian rubbish.
I did buy the correct oem eccentric bolts for the rear arms, the quality of the new ones from Porsche was appalling compared to the originals.
The sliver factory coating on its bolts offers zero anti seize protection, I always add something better.
Gazc2
Watkins Glen
PostPosted: Wed Oct 30, 2019 4:59 pm    Post subject: Reply with quote
Thanks for the replies gents according to PET its a
ST4,8 speednut
4x8x16 screw
The screws are readily available on Ebay
man in the states has 1 for a tenner Very Happy
https://www.ebay.co.uk/itm/Porsche-911-Boxster-Speed-Nut-ST-4-8-For-Fender-Liner-NEW-NS/163491680645?hash=item2610dd1185:g:DSQAAOSw7vBdlEMK
man in hong kong has 20 for £3
https://www.ebay.co.uk/itm/20pcs-Spring-Steel-Speed-Fastener-U-Nut-Clip-Black-for-M5-ST4-8-Screw-Bolt/362150046031?epid=2279753066&hash=item5451d3294f:g:EZ4AAOSwxuRdWPYM
will have another shufty around tonight maybe give Namrick a try.
65p on design911 which means OPC will probably work out cheaper
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
kul997
PostPosted: Wed Jan 15, 2020 11:29 pm    Post subject: spire clips/speednuts source ? Reply with quote
I managed to get these from Wurth. As good as the originals but for pennies and galvanised.
Gazc2
Watkins Glen
PostPosted: Thu Jan 16, 2020 9:14 am    Post subject: Reply with quote
I ended up getting them from OPC at £0.39 +vat do you have a link to a source for the worth ones ?
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
