997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
v6matt
PostPosted: Mon Oct 28, 2019 9:39 am    Post subject: Does anyone have 997 TSB 6416-Whistling Noise In The A-Pilla Reply with quote
A noise that sounded like a kazoo started up when driving over 50 yesterday.
I tried cleaning out dead leaves e.t.c but no change, then I came across a thread on another forum that said this...
"Sometimes at speeds 60mph and higher, there would be a kazoo noise coming from the passenger side windsheild at what I thought was the dash/side view mirror area. I looked at everything in the area, removing panels ect. and nothing fixed it. I looked at TSB 6416 but didn't think much about it because it showed the area in question was at the top of the windshield.
One day I was looking around again, and sure enough, the seal around the windshield was loose on the passanger side up high (side of the windshield, not top). I purchased some butyl tape (per TSB) off Amazon.com, 1/4" round 3M, and followed the TSB installation and I can say now the noise has gone away.
It was very annoying and I even took the car into the dealer, but of course they couldn't duplicate the noise."
I think it's time for a Porsche fix, I have found the 6mm Butyl rope from 3M (called 3M™ Scotch-Weld™ Preformed Sealant Strip 5313)
However I want to look at "TSB 6416 Whistling Noise In The A-Pillar Area At High Speed" to see how/where I apply.
Has anyone got a copy, can point me in the direction of where one lives.
2008 Carrera 4 - Gen 1 997
PostPosted: Mon Oct 28, 2019 7:23 pm    Post subject: Reply with quote
I dont have the TSB im afraid and cant get it ..
Wind noises though are often caused by a sharp edge .. similar to getting a blade of grass .. holding in between your thumbs and blowing on it .. well .. that's what i did as a kid anyways .. no internet and only 3 tv stations back then lol .
Basically anything that stops a sharp edge will stop the noise .. perhaps silicone down the screen rubber if i understand the fault correctly .. that might stop it .
Picture of the fault area ?
jl-c
PostPosted: Mon Oct 28, 2019 8:01 pm    Post subject: Reply with quote
try this Very Happy
Carrera__997__Whistling_Noise_In_The_A_Pillar_Area_At_High_Speed.pdf
Download
 Filename:  Carrera__997__Whistling_Noise_In_The_A_Pillar_Area_At_High_Speed.pdf
 Filesize:  77.05 KB
 Downloaded:  54 Time(s)
v6matt
PostPosted: Mon Oct 28, 2019 8:17 pm    Post subject: Reply with quote
Very Happy Very Happy thanks for suggestion deMort. Thumb
In terms of the location, that is the problem there isn't anything immediately apparent but based on that TSB that has seen been posted, it seems to be caused by wind pressure increasing at speed and then pushing on the screen.
Seemingly Porsche struggled with fitment at the factory, and mine has had a new screen since it came out and been subject to the recent super heat, so that has likely introduced this glitch (and undid Porsche's fix in the factory).
The butyl rope is thicker than required on the 993 and 996 fix.
v6matt
PostPosted: Mon Oct 28, 2019 8:18 pm    Post subject: Reply with quote
jl-c wrote:
try this Very Happy
You superstar ! Dance Tap Dance Tap
v6matt
PostPosted: Tue Oct 29, 2019 6:19 pm    Post subject: Reply with quote
Interesting find today, I put the passenger window down slightly on the car today and having dropped the window about 2 cm, the noise vanished !!
So I suspect I also need to look at the door/mirror seals. This was probably me when I pre-emptively applied Gummiphleger (Rubber reconditioner) to all the door seals e.t.c
I wonder if I disrupted something (somehow) in doing so. The joys of 911 window and mirror seals ! I thought my previous Alfa's were picky !
Anything to look for folk?
MaxA
PostPosted: Wed Nov 13, 2019 8:07 am    Post subject: Reply with quote
Thanks for this (love this forum!). I've had that squeal for a while, but since I rarely just schlep along motorways, I keep forgetting about it.
Now I have to add it to the list... Surprised
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Wed Nov 13, 2019 11:24 am    Post subject: Reply with quote
Here's something simple to check......
When you unlock the car both side windows drop few mm to facilitate the doors opening.
When you enter the car and close the door the window returns to the fully closed position.
I found that the passenger side was not returning (997 and this week my 991)
Once you have fired her up.......try the toggling the switch to see if the window rises.
Cause....low charge of the battery. As we are quickly getting into winter, batteries that are not fully charged get "found out" by the cold weather.
If you don't do many miles a week, it may be the case that you need to give it a 20+mile run and then have the battery checked.
A trickle charger may be a wise investment.
It is amazing how much noise just a few mm of lowered window can generate.
I hope this is the answer Thumb
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
v6matt
PostPosted: Thu Nov 14, 2019 4:21 pm    Post subject: Reply with quote
Thanks, not the case on mine. I think with the extreme heat of the summer, it must have slightly distorted the windscreen rubber. So I used this TSB and have fixed one side, the other has been improved but I need to look at it again when it's not raining :/
