997 : 2004- 67
Boxster : 1997- 31
Pickse
PostPosted: Sun Oct 27, 2019 5:22 pm    Post subject: 996 Window Drop on Door Open Reply with quote
I have what I have read is a common problem with my 996 passenger door.
When I lift the door handle the window drops a few mm as expected but when I release the handle, with the door open, it raises backup again making it difficult to shut the door.
I figure the car does not know the door is open and, I think confirmed this by locking the car via key fob with the pax door open. The locking sequence is happy completed and signaled by two flashes of the indicators.
If I try this with the drivers door open I get a beep indicating somethings wrong.
I see the handle switch here https://www.deroure.com/diagrams.asp?TBL=3326&MAK=3&MDL=28&SMA=0&SMO=0&ST=99737503303&SC=1
But this switch is obviously working and I see posts which mention 'switches' in the door handle but I only see one, so my questions would be:
Where is the switch which tells the car the door is open?
Inside the door lock maybe? There is not mention of a separate switch?
https://www.deroure.com/diagrams.asp?TBL=3324&MAK=3&MDL=28&SMA=0&SMO=0&ST=99737503303&SC=1
Thanks for any advice,
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
pzero
PostPosted: Sun Oct 27, 2019 5:49 pm    Post subject: Reply with quote
http://www.911uk.com/viewtopic.php?p=928543&sid=db1fa0743759a8f8db91c388f62bb589
991.1 Carrera GTS
PostPosted: Sun Oct 27, 2019 6:53 pm    Post subject: Reply with quote
You have already answered your own question Smile
The door doesnt know its open so only reacts to the handle switch .. hence you can lock the car with it open but no horn warning beep.
The door lock ass has the switches that tell the car its open or closed .
