997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
Grey996
PostPosted: Mon Nov 11, 2019 3:40 pm    Post subject: Reply with quote
Thanks, yes Millers provided a similar sheet listing the types of metals found, I was interested in whether the amounts found where indicators of anything?
2002 Porsche 996 C2
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Nov 11, 2019 4:50 pm    Post subject: Reply with quote
The analysis is of more benefit when you have baseline values and can see a trend over time.
GMG
PostPosted: Mon Nov 11, 2019 5:29 pm    Post subject: Reply with quote
...oil analysis is a waste of money unless you do it every few miles as analysis can show nothing of note one reading to my crankshaft is fooked the next as the bearing shells wear through to the copper !
Robertb
PostPosted: Mon Nov 11, 2019 6:34 pm    Post subject: Reply with quote
I recall it saved poppopbangbang some trouble when analysis picked up an issue (though not a bearing) before it got worse.
Grey996
PostPosted: Mon Nov 11, 2019 7:01 pm    Post subject: Reply with quote
Thanks that makes sense but does anyone have any ballpark values of a ‘healthy’ engine?
2002 Porsche 996 C2
PostPosted: Mon Nov 11, 2019 7:08 pm    Post subject: Reply with quote
Yeah - 0% Grin
Robertb
PostPosted: Mon Nov 11, 2019 7:39 pm    Post subject: Reply with quote
If the Millers guy says it’s ok then I’d run with that.
Get on and enjoy your car and stop worrying!
skinny_monkey
PostPosted: Mon Nov 11, 2019 10:20 pm    Post subject: Reply with quote
Very roughly, you are looking for around 10ppm or less of wear metals. Your readings look fine. Google blackstone oil analysis, a lot of Americans post up their readings with oil mileage so you can set what's typical for the 996.
Iron is crank / cams and i believe IMSB is iron alloy too
Ali is pistons
Lead and copper is bearings
Oil analysis detects conventional wear. It's useful to keep an eye on how things are generally looking and particular trends. It can't detect or predict sudden or catastrophic failures, but these are not often caused by excessive wear (for example can be inherent material faults or weaknesses)
Grey996
PostPosted: Tue Nov 12, 2019 12:29 pm    Post subject: Reply with quote
Ali is pistons
2002 Porsche 996 C2
Goto page Previous  1, 2, 3
Page 3 of 3
