997 : 2004- 67
Boxster : 1997- 31
JM30
PostPosted: Fri Oct 25, 2019 11:36 am    Post subject: Help please - power steering pressure pipes Needed. Reply with quote
Hello all, as title I’m in the Costly process of having a reconditioned steering rack fitted due to wear and play within (excuse my non technical explanations!!)
As with anything on these blooming cars nothing likes to come apart nicely so having to get new lines ones a pressure line and the return line
Porsche part number - 99634745204
And
Porsche part number - 99634745012
Both very costly and I’m quite shocked to say the least, after chatting to Iain via PM he mentioned a few have had companies make them up at a much reduced price can anyone pleased forward me the details 🙏🏼
Any help is much appreciated
Current cars
-996.1 C2 GT3 Aero Kit White
-Classic Mini 1275cc China Grey
NXI20
Paul Ricard
2004 Porsche 996 GT3 Mk2
PostPosted: Fri Oct 25, 2019 12:39 pm    Post subject: Reply with quote
These guys should sort you out. Onsite service too Thumb
https://www.pirtek.co.uk/
Nick
1978 Carrera SC in Red (for sale)
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Oct 25, 2019 12:56 pm    Post subject: Reply with quote
Are these what you mean?
https://www.design911.com/Replacement-pipes-for-RHD-steering-rack-Porsche-986---996/prod138271/
JM30
PostPosted: Fri Oct 25, 2019 2:32 pm    Post subject: Reply with quote
NXI20 - Many thanks for that, have you used them before? I shall give them a shout now, Thumb
Robertb- I’m hoping they should come with the reconditioned rack but I may need a set of them, the ones in question are different and run to the rear of the car nearly £1000 from Porsche Sad
Current cars
steve r
PostPosted: Fri Oct 25, 2019 4:40 pm    Post subject: Reply with quote
I'm sure i read somewhere that someone used the shorter and cheaper 997 front hoses and had them connected to the long hoses that go to the rear of the 996.
40th Anniversary
JM30
PostPosted: Fri Oct 25, 2019 5:12 pm    Post subject: Reply with quote
Thanks Steve, that’s interesting, I did send my guy a diagram that happen to be of a 997 but he said he isn’t sure and has only ever changed the complete line, I’m frustrated at this not only due to the expense but why an aftermarket option isn’t available by now!, Is it common to change these pipes?, he said it’s 9/10 fused and will either damage the rack or pipe removing them 😖
He is removing them for me to drive to my local pirtek In Ashford to see what they can do but in the meantime please do forward any information guys/gals as I’m not confident they can help, neither is Steve@goss hall classics that is dealing with this for me but that’s mainly because he has never heard of another way or place doing this.
Iv got it in my mind to damn well try get around this!!
Current cars
steve r
PostPosted: Fri Oct 25, 2019 5:54 pm    Post subject: Reply with quote
No problem.
it could be worth trying Think Automotive too. They have made up oil and fuel hoses for me in the past so may be able to help https://www.thinkauto.com
40th Anniversary
steve r
PostPosted: Fri Oct 25, 2019 6:00 pm    Post subject: Reply with quote
Found some info here http://www.911uk.com/viewtopic.php?p=1110490&sid=5cf108f63df24f7925a96628edf29411
997 hoses lengthened to suit the 996
40th Anniversary
crash7
PostPosted: Fri Oct 25, 2019 6:15 pm    Post subject: Reply with quote
The issue you have is that, as you have touched upon, the pipe ends that fit into the rack suffer dissimilar corrosion, steel pipe, aluminium rack.
The only way to get the rack out of the car in many case is to cut the power steering pipes.
The next issue is that ends of the pipes are Porsche specific, not a standard JIC, AN etc fitting.
So while Pirtek and the like may be able to make you up a hose, the standard Porsche lines are made up of a mix of steel pipe and rubber hose, and are a long and an intricate shape, they will not have a compatible fitting to replicate the Porsche specific item that fits into the rack.
I recently installed a 997 Cup car electric power steering pump on my 996 and spent time working out and sourcing what I needed. - In addition to removing all of the original power steering lines.
I made up custom hoses and can provide the info if required, however my power steering pump is now located in the frunk, not bolted to the engine so a much shorter and less complicated run.
If you prepared to go totally custom on the lines and want the info let me know, however there is no straight forward, like for like aftermarket solution.
JM30
PostPosted: Sat Oct 26, 2019 8:20 am    Post subject: Reply with quote
Steve R - thank you so much for taking the time to find and post that link, very interesting and could well be another route, I forwarded it to my guy and hoping to hear back from him (he is the one doing it so very much restricted to what he wants to do) I will be the one that is having these made but any fitment issues will be on my back if I don't get it right,
Crash7 - That is an issue too, as you say he may have to cut the pipe close to the connections but I'm hoping when it's off he can safely remove the ends for me to take, he did advise me that the fittings are like no other! typical, the pipes are being removed regardless so I will have them to hand and take them with me however I'm not holding to much hope,
your electric power steering conversion sounds very cool unfortunately not something I would likely be able to do myself and would cost me an arm and leg in labor costs if I had the place do it for me? Razz I don't mind trying something outside the box so to speak, the guy dealing with this has been great and he knows me but I feel he thinks I'm going on a wild goose chase trying to get round buying OE pipes..
Cheers guys,
Current cars
Hamblemark
PostPosted: Sat Oct 26, 2019 9:02 am    Post subject: Reply with quote
I feel your pain, having had to refurb my steering rack following the hard pipes splitting and facing the lottery of the return pipes. As with your case, they were welded into the rack.
In the end I bit the bullet and went with the OEM route on the basis once it was done, neither I or any future owner would need to worry again. Similar to the corroded brake lines I replaced two years ago.
Negligible depreciation on the motor comes at a cost - you have to keep investing to maintain its value.
996 C4S - Polar Silver
JM30
PostPosted: Mon Oct 28, 2019 7:52 pm    Post subject: Reply with quote
Bullet now well and truly bitten frustrated Sad Porsche are now £1k richer as of today and I'm livid,
Hamblemark - I hear what you are saying and sometimes just knowing it's now done and dusted is all I can take for comfort, It's got to be £2k spent on the most boring and unsatisfying automotive part possible steering rack + pipes! what
I could have pushed more to have something made up but time between work and the place I'm using getting a little frustrated with my car in the way I felt the pressure to just bite the bullet on this, not to mention the places I called giving me mixed signals, understandably wanting a week or so to sort something out but not sure they can get the Porsche type fitment,
Thanks for all the help, genuinely annoyed because I feel this can be done (and has been) as shown by some of you, I wish I had more time on it.
I really hate this time of the year adds to what feels like a waste of money Roads are awful around here thick of mud and flooded boo..
Current cars
PostPosted: Mon Oct 28, 2019 8:00 pm    Post subject: Reply with quote
Sorry i couldn,t be of more help young man .. i simply didn't have an answer for you Sad
Strange as it may seem .. i've not had to do this to date nor have my colleagues .
Lee997
PostPosted: Mon Oct 28, 2019 8:22 pm    Post subject: Pirtek Reply with quote
As stated just take them to your local Pirtek centre!
As a ex- Pirtek centre owner, we would either make new or repair power steering pipes most days at a fraction of OEM price.
Lee
JM30
PostPosted: Mon Oct 28, 2019 8:22 pm    Post subject: Reply with quote
Hi mate, no thank you for getting back to me on this, really nice to have someone like yourself to just be able to contact Wink
As you say It was a hard one to diagnose, one reason why this has been an issue on the car for the last two owners I would imagine! I just ended up being the one to get it sorted, this isn't a dig at all to either owner by the way! what I mean is I don't think anyone of them would put it down to play in the rack itself, I certainly didn't, within 1min of test driving I felt this knocking through the steering wheel and I was thinking 200-400 max will sort this, Centre gravity changed all sorts on this already according to the invoices, so I did track rods anti roll bar bushes drop link, suspension arms and now new rack, the pipes are just the unlucky side of having to change the rack as you know on most of these older 911's, I did hear the steering rack is not a common fault more so now you say it!
Thanks again
Current cars
JM30
PostPosted: Mon Oct 28, 2019 8:30 pm    Post subject: Reply with quote
Hi Lee, Can I ask would this certain fitting on the OE Porsche ones be available to you at Pirtek? I spoke to Ashford branch (great on the phone just not had chance to get down there) but she wasn't sure the fitting I needed would be right and mentioned the metal piping if it's not a straight forward design could be a problem so sort of put me off due to already feeling the pressure from the garage this morning,
I'm not taking delivery of the Porsche pipes until Wednesday,
Current cars
