997 : 2004- 64
elwyn
PostPosted: Thu Oct 24, 2019 6:09 pm    Post subject: gear box ready to drop Reply with quote
hi folks, just ready to drop my gear box and refurbish brake pipes etc. thought this would be good time to replace seal on ims cover as i do have a small weep, can anyone tell me what to look for when im in there, and what seal is best,i have no intention or had no intention of removing the brg if all looks good. just for interest i have added up how long it took me to remove ONE bolt from bell house six and half hours, over three evenings, thats with a lift. 2004 carrera just coming up on 80000 miles, drives superb thanks for reading, really enjoy forum bye
PostPosted: Thu Oct 24, 2019 7:13 pm    Post subject: Reply with quote
Box out , flywheel off and you have x2 seals .. the crank seal ( RMS ) and the IMS seal .. that's the bottom one ..
You basically look to see which one is leaking .. it's pretty obvious to be fair .
To replace the RMS then there is a special tool to fit it .. no idea if it can be done without as i use the tool .
To change the IMS seal then you have to lock the crank , lock B1 cam shafts , drop the tensioners then remove the seal which is basically a metal cover with 3 bolts and a rubber seal on it .
X2 small pry bars are needed to remove it .
DO NOT just try and pull it out without doing the above or you will be in a world of pain .
996 workshop manual is in the faq section .
Read the manual or i can give more detailed instructions if needed .
elwyn
PostPosted: Fri Oct 25, 2019 6:44 am    Post subject: gear box ready to drop Reply with quote
thanks demort for reply, waiting for help to drop box, hopefully this weekend, have all ready, anybody out there who will sell, rent or loan camshaft locking tools. regards to all Question
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sat Oct 26, 2019 8:12 pm    Post subject: Reply with quote
Check my thread linked below, I did AOS and gearbox mount bush too
I made the cam tool, 10 mins with a bit of alloy plate.
Also clutch, fly, RMS, flipped seal on IMS bearing, brake pipe etc etc
On my back on axle stands on my drive....in the snow. Its not too difficult just needs some perseverance....
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Oct 27, 2019 12:09 am    Post subject: Reply with quote
If it takes you that long to get it back you would be better to drop the engine and fit them together. I'm sure I dropped then engine and gearbox in about 3 hours.
elwyn
PostPosted: Sun Oct 27, 2019 9:31 am    Post subject: gear box ready to drop Reply with quote
hi folks, thanks for reply, reason so long with gear box was one gear box bolt was ceased solid, i mean solid, i didnt want to snap or ring it. it took a lot of time and LOT patience , fought me to the last thread, stronger than a weld, again steel into alloy Evil or Very Mad
elwyn
PostPosted: Sun Oct 27, 2019 9:38 am    Post subject: lock tool Reply with quote
folks , did i see a drawing of home made cam lock tools with all measurements on this site 3 chain engine ? Question
