997 : 2004- 67
Boxster : 1997- 31
NotoriousREV
PostPosted: Wed Oct 23, 2019 2:17 pm    Post subject: PSM Off and ABS warning lights Reply with quote
After 15 mins driving both of these lights are coming on. I’m not getting an engine check light and they clear when the car is restarted. Is there a way to diagnose this without a scanner? Do any of the eBay OBD scanners work on 996s (mine’s a 1999 C4) or do I need a Porsche specific one to read everything?
PostPosted: Wed Oct 23, 2019 2:41 pm    Post subject: Reply with quote
Porsche specific. Although there are some basic checks you can do yourself like checking brake and clutch pedal switches. First though I'd be a bit more specific on what/when/why they're coming on. Eg. Are you in motion when it happens or can you make it do it when stoppd, etc.
NotoriousREV
PostPosted: Wed Oct 23, 2019 2:59 pm    Post subject: Reply with quote
I haven’t tried it any other way but they come in whilst in motion after driving for about 15 minutes. It’s happened on the last 3 times I’ve taken it out.
PostPosted: Wed Oct 23, 2019 3:07 pm    Post subject: Reply with quote
Are you cornering at the time, driving spirited, braking, changing gear , etc?
NotoriousREV
PostPosted: Wed Oct 23, 2019 3:13 pm    Post subject: Reply with quote
Just cruising on the motorway.
PostPosted: Wed Oct 23, 2019 3:16 pm    Post subject: Reply with quote
Pass.
ViciousViper
PostPosted: Wed Oct 23, 2019 3:33 pm    Post subject: Reply with quote
I had the exact same symptoms. Turned out my ABS pump was toast Rolling Eyes
'99 996 Carrera 4 / 3.6 X51 Aero Cup - Arctic Silver
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Oct 23, 2019 3:47 pm    Post subject: Reply with quote
Maybe ABS wheel speed sensor? OBD will tell you.
PostPosted: Wed Oct 23, 2019 3:50 pm    Post subject: Reply with quote
deMort will probably know.
PostPosted: Wed Oct 23, 2019 6:29 pm    Post subject: Reply with quote
I'm afraid you need a tester to read out fault codes or watch actual values of the speed sensors whilst driving to locate the fault .
It's going to be heat related hence after 15 mins of driving and i suspect a wheel speed sensor is under reading at that point but without checking codes / values then there is no easy way to determine the fault .
Pre fault code days and we had to scope each sensor and test every relay , wiring connections etc to find a fault .. huge amount of time taken doing it this way .
I will say that the driveshaft rotors on 996 are corroding badly these days .. a judder on the pedal at low speed will indicate this as the abs has kicked in at approx 10 mph due to the sensor seeing almost joined up segments due to the rust .
Not your fault but something for others to consider .
NotoriousREV
PostPosted: Wed Oct 23, 2019 8:23 pm    Post subject: Reply with quote
Cheers deMort, I’ll book it into my usual indy to get it read. My indicator switch has broken today, too. This could be a pricey week.
PostPosted: Thu Oct 24, 2019 7:35 pm    Post subject: Reply with quote
It's starting to sound that way but fingers crossed it won't be .. a fault code and i can help further .
