997 : 2004- 65
Cayman : 2005- 22
Macan : 2014- 8
MarkGolf
PostPosted: Tue Oct 22, 2019 12:25 pm    Post subject: Stiff knob in Boxster 2.7 986 Reply with quote
Ohhh err.... it's true, you read it right..
In my Boxster 986 2.7, the knob is stiff when going side to side, it has one of those cheapo short shift kits but even after loosening it and eventually undoing the linkages, the actual linkage feels stiff. This led me to go and coat everything at the gearbox end in WD40 while someone was pulling the linkage, still stiff..
Any ideas what's up?
I am due to change the gearbox fluid this week, I doubt that will change anything but just mentioning.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
PostPosted: Tue Oct 22, 2019 1:30 pm    Post subject: Reply with quote
Mark it could be a number of things, have you got the original shifter kit you could refit and try at least that way you can establish if its the cheapo SSK or something else . Thumb
PostPosted: Tue Oct 22, 2019 4:00 pm    Post subject: Reply with quote
I had to read this twice Surprised as I thought it would concern Jonttt stroking all that carbonique.
Then I realised he has a 987.2 'Last of the true Authentic Breed Boxster' Rolling Eyes
Could it be the rubber gaiter perishing Question
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
MarkGolf
PostPosted: Tue Oct 22, 2019 4:19 pm    Post subject: Reply with quote
Hi Phil,
I took the shifter out of the equation so I can't blame that..
When pulling the cable, it feel a bit tight and gets stuck, as if a spring is missing..
We're bareback in the Boxster, no rubbers to worry about. Hand
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
PostPosted: Tue Oct 22, 2019 6:42 pm    Post subject: Reply with quote
Sounds like a stiff selector rail. Dont know
Oil change may help.
PostPosted: Tue Oct 22, 2019 7:08 pm    Post subject: Reply with quote
My guess would be the cable .. they can partially seize .. it should with both ends disconnected move like silk .
Again with the cable disconnected the gear lever should move easily .
This is normally a Tip problem and as such its the linkage or a tight bolt on the lever but both of those are not really applicable to a manual .
i have had x1 tip which was the cable though .
One of those jobs i need to look at to say whats wrong im afraid .. sorry .
MarkGolf
PostPosted: Wed Oct 23, 2019 10:01 am    Post subject: Reply with quote
Yeah, without removing the undertray and getting my hand on that bit without the cable attached, I can't be sure but I think i'll get the 'box fluid done and go from there..
Cheers Iain, I'll do my fluid change and if it doesn't loosen up, I'll detach the side-side cable from the box end and see how it feels! Something is sticking, I can move the gear knob to the left and 70% of the time, it just stays there, it doesn't spring back..
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Oct 23, 2019 2:04 pm    Post subject: Reply with quote
spray some oil on the rose joint bit that connects the cable to the box.
MarkGolf
PostPosted: Fri Oct 25, 2019 10:45 am    Post subject: Reply with quote
Just to update,
Did a fluid change on the box, oil stuff out, was like a black coffee, runny as fcku too.
New stuff in, Catrol Syntrax transaxle 75/90. Had to go for an 45 minute drive last night and used it again to go in to the office today, box instantly felt better, knob is springing back, actually goes into gear much smoother and I'm almost certain the car itself feels smoother when pulling away and accelerating, almost cushioned..
Easy job Smile
Cheers all!
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
PostPosted: Sat Oct 26, 2019 5:25 pm    Post subject: Reply with quote
MarkGolf wrote:
Just to update,
Easy job Smile
Cheers all!
Always good to read a fix that was easy and inexpensive Thumb Thumb
The return of Marty Wild
PostPosted: Sat Oct 26, 2019 7:32 pm    Post subject: Reply with quote
Enough about the driver, tell us about the car....
Boxster S 986.1
Cayman S 987.1 (gone but not forgotten)
wasz
PostPosted: Sat Oct 26, 2019 7:58 pm    Post subject: Reply with quote
maybe too late but there is a magnet in the box just next to the drain, stick your finger in and wipe round to clear the accumulated debris off it
actually that might only apply to an "S" or 996 with getrag box
MarkGolf
PostPosted: Mon Oct 28, 2019 3:05 pm    Post subject: Reply with quote
Too late for me to check. Maybe in 10 years time Very Happy Very Happy No more stiff knobs here, just a flacid one. Thumb
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
PostPosted: Mon Oct 28, 2019 6:37 pm    Post subject: Reply with quote
Mine didn't have one so my mechanic fit one to the drain plug. Dont know
