997 : 2004- 67
Boxster : 1997- 31
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Oct 22, 2019 10:18 am    Post subject: Weird parts prices... Reply with quote
Just a random musing, while I consider two parts I need for my 996 4S.
How can a bloomin' light switch cost the same as two RS spec engine mounts and fastenings??
PC
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Tue Oct 22, 2019 2:26 pm    Post subject: Reply with quote
It does seem utterly bonkers sometimes. Some parts seem crazy expensive and others more than reasonable.
I replaced the under bonnet plastics on my 996 as the tangs and edges were tatty and broken.
The left hand cover and the battery cover were about £20 each but the right cover( with the window for the vin) was nearly £40!
I questioned this with the OPC and even phoned 3 others only to find the price was the same on all of their systems.
Every parts person expressed amazement at the variance and was at a loss to give any reason as to why they should be so different in price.
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
PostPosted: Tue Oct 22, 2019 6:43 pm    Post subject: Reply with quote
Trust me when i say im often shocked at the price Porsche charges for items ..
Over the years .. and my theory .. the more Porsche start to sell a particular item then the more they raise the price of it .. i've seen this many many times .
924 inlet pipe assembly i ordered last week .. i figured £150 ish .. it was £30 , they had 3 in stock in the UK .. it was made in 2014 when i saw the date stamp .. they just don't sell them hence they are cheap.
Some parts have to be remade as they run out of stock .. i can understand these being more expensive .. Porsche has basically had to pay out to have another several hundred items made that will sit on a shelf for many years to come .
My guess anyways .
Cheburator
PostPosted: Tue Oct 22, 2019 8:00 pm    Post subject: Reply with quote
Porsche use a variety of pricing mechanisms...
My GT3 gearbox was modified by Manthey - my 3d gear is off a 993 GT2 - original invoice cost - about £800... Now that the 993 GT2 costs north of £1m, the price miraculously has jumped up to £2400 odd...
The 928 GT pinion and crown wheel went from £900 to £2500 recently, yet the stronger and rarer 928 GTS pinion and crown wheel are sitting at £800 odd.
My favourite - the 944 LSD uses friction discs straight off the 917! Yes, they do carry a part number along the lines of 917.XXX - cost -£17 each...
Porsche 996.1 GT3 CS K400
Porsche 928 GTS 5-spd
Porsche 944 Turbo Cup race car
Porsche 928 Cup race car
Various BMWs
