997 : 2004- 64
DJones
PostPosted: Mon Oct 21, 2019 8:13 pm    Post subject: Dog bones finally fitted Reply with quote
Hi
Been meaning to fit these for ages, my car is quite low and consequently had too much negative camber -2.3 degrees.
I fitted the dog bones at the weekend, I had the toe links already. I set the camber at -1 degrees and subsequently set the toe. It drives so much better and given it now puts a flat foot print down has significantly reduced wheel spin when you’re right foot gets heavy.
Good modification if needed with no noticeable ride quality concerns.
Darren
2002 996 GT2 recreation in Nogaro blue
2017 Ferrari 488 GTB Nero black
2006 Ford GT40 Gulf Racing colours
1994 AC Cobra 427 Guardsman blue
 Filesize:  343.37 KB
 Viewed:  523 Time(s)
 Filesize:  459.57 KB
 Viewed:  523 Time(s)
Rosselder83
PostPosted: Mon Oct 21, 2019 8:43 pm    Post subject: Reply with quote
Looks like a good bit of kit. Where did you get them from?
DJones
PostPosted: Mon Oct 21, 2019 9:05 pm    Post subject: Reply with quote
Thanks, Design 911.
