997 : 2004- 65
Cayman : 2005- 22
Macan : 2014- 8
Silver2
PostPosted: Mon Oct 21, 2019 3:45 pm    Post subject: New discs and pads Reply with quote
Hi All
First post from a long time lurker. It's time for new from discs and pads and I'm looking at 3 options for my Gen 2 S.
All in costs from my Indy are:
Porsche parts - £750
Pagid - £450
Sebro/ATE - £500
Opinions and words of wisdom much appreciated.
PostPosted: Mon Oct 21, 2019 4:08 pm    Post subject: Reply with quote
Pagid are fine for road use.
jl-c
PostPosted: Mon Oct 21, 2019 4:47 pm    Post subject: Reply with quote
+1 yes
P9XX
PostPosted: Mon Oct 21, 2019 5:05 pm    Post subject: Reply with quote
Agree about Pagid.
I have original discs and replacement Pagid pads and wear sensors in mine.
No squealing or graunching.
You might need new wear sensors. They tend to suffer heat damage to the plastic fitting in the pad and can crack on removal.
New caliper to hub bolts ? (4 off)
Some say they're non-stretch so don't need replacing. I would, due to likely corrosion on the exposed thread.
Anti-squeal / anti-rattle shims can be peeled away from the old pads.
They adhere to the pad backplate with a self adhesive foam.
With the caliper off the hub, it may be a good idea to replace these if necessary.
In any case, a good opportunity to clean the old ones if not replacing.
2008 997.2 C2S PDK Basalt Black
easternjets
Watkins Glen
PostPosted: Mon Oct 21, 2019 8:10 pm    Post subject: Reply with quote
The bolts are non stretch and no part other than the tip is exposed to the elements. I've never replaced them, I just torque them up when refitted.
Pagid are used by VW on their cars as standard. Textar are also good and more than adequate for road use.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
hermes
PostPosted: Tue Oct 22, 2019 10:39 am    Post subject: Reply with quote
I've just fitted Hawk Ceramic pads to my fronts to see if it cuts down on the dust.
PostPosted: Tue Oct 22, 2019 6:51 pm    Post subject: Reply with quote
I seem to remember the name Pagid on the boxes at work at times Very Happy
