997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
AK996
PostPosted: Tue Feb 11, 2020 6:50 pm    Post subject: Reply with quote
Just thought I would give an update.
I still have the same problem with the fuel, so took it back to them Potiacraft.
Portiacraft say they have replaced the sender from another car but the gauge is still not working correctly.
I have since removed the sender to check the tank, looks OK and clean not imploded thank goodness.
I decided to take the car to another specialist who has a PIWIS2 for calibration..
He could not calibrate the fuel gauge. Then discovered the instrument cluster was from another car as it had a different chassis number assigned to it. He coded this to match the car and calibrated, still no joy.
As it stands he is suggesting it could be the float or the instrument cluster.
I have since driven the car for 100 miles after the warning light and -- sign came on. So I know the petrol is in there.
Does anyone know if I can test the fuel level sensor or the instrument cluster?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Feb 11, 2020 7:13 pm    Post subject: Reply with quote
Was the cluster from a car with the same tank? I know they are different between the C2 and C4 as if I run my C4 cluster in my C2 it reads a lot higher.
AK996
PostPosted: Wed Feb 12, 2020 11:53 am    Post subject: Reply with quote
That is a very good point.
I have booked it back into Portiacraft on the 19th.
They say they will put a trial cluster to see if thats the problem.
Thank you very much.
Goto page Previous  1, 2
Page 2 of 2
