997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayenne : 2003- 7
AK996
PostPosted: Wed Oct 16, 2019 6:59 am    Post subject: 996 c4s fuel tank capacity? Reply with quote
Hi
After many years I finally bought a Porsche 911 (996 c4s)
The low fuel message appeared saying I had 34 miles left to empty tank so I filled up to the brim. It took just 29 litres and the tank was full? The fuel gauge shows full and the trip shows 204 miles range.Have driven apprx 40 miles and the gauge shows 3/4 so seems to be working.
Is this normal or is something wrong?
Any help would be appreciated
Billy Bumpsteer
PostPosted: Wed Oct 16, 2019 7:22 am    Post subject: Reply with quote
Normal, C4 tanks only gauge the first half or so of the tank, do a search, it comes up alot!
PostPosted: Wed Oct 16, 2019 7:23 am    Post subject: Reply with quote
As above. the gauge only measures the top 2/3rds then its guess work off the ECU.
Tank holds around 62 litres.
AK996
PostPosted: Wed Oct 16, 2019 7:55 am    Post subject: Reply with quote
Thanks for the quick replies.
I searched the posts where the fuel gauge did not register a small top up, did not realise the same issue would be there when the fuel gauge shows full.
So will not really know the true range will be.
Will get some getting used to.
pzero
PostPosted: Wed Oct 16, 2019 7:57 am    Post subject: Reply with quote
As the posts above have already said, nothing to worry about.
OP, Billy Bumpsteer is quite correct in saying that a quick search of the forum would throw up the reassurance you were seeking.
Here's one previous thread, other threads are available;
http://www.911uk.com/viewtopic.php?t=89198&postdays=0&postorder=asc&start=0&sid=3282765d62063adf69b4aad7b45d0bdf
Oh, and Welcome to 911uk. A pic or two of your C4S would be good. Thumb
991.1 Carrera GTS
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Oct 16, 2019 8:36 am    Post subject: Reply with quote
Its possible the previous owner/dealer put a bit of fuel in as the range had gotten low, but for the reasons pointed out above the car did not register it. Once you filled it up then it correctly registered.
Enjoy your new car!
PostPosted: Wed Oct 16, 2019 6:55 pm    Post subject: Reply with quote
The fuel tank holds 63 litres so a refill that took only 29 ltrs is approx 50 % of the tanks capacity .
It wasn't totally empty but had approx 9 ltrs left in it till empty.
38 ltrs measured so we are missing 25 ltrs ??
The calculated value IMHO is roughly bottom third so approx 20 ltrs .
I would run it again until it says empty then see how much fuel you put into the car .. if still 30 ish liters then it's not right .
My suspicion is you need a fuel sender calibration doing as the calculated amount seems to be missing .
From memory and i thought that a full tank gave a range of approx 285 miles .
Quote from another post ...
it is 64 litres. But I've crammed 67l in with 10m still showing on range, but that's including the spout.
Not sure why it's important though. Just fill up when the remaining range gets below your comfort level.
You should get a range of 250-270m if you're urban, or thrashing it, and up to high 400's on a long run at motorway speeds.
Indy Mechanic .
 Filesize:  272.19 KB
 Viewed:  1957 Time(s)
AK996
PostPosted: Wed Oct 16, 2019 8:27 pm    Post subject: Reply with quote
Thank you for all the replies and the link.
Although i have the car the dealer will be checking it over and servicing it next week and handing it over to me officially. I will let him know that it needs a fuel sender calibration so that really has helped thank you.
I will of course take your advice and run it low and refuel to full.
I have now driven in town for 50 miles, the range has dropped from 204 at full tank down to 75 miles, trip showing 14.8 mpg So as it stands I will be getting 125 miles to a full tank.
Nice to know theres help out there.
paulstevens64
PostPosted: Thu Oct 17, 2019 2:17 pm    Post subject: Reply with quote
The other alternative is that the tank has partially collapsed.
If the pressure release valve does not work, then the tank can implode and buckle.
As a result the capacity of the tank would be reduced. If the bottom half is ok but the top half is collapsed, then you would get your fuel warning (based on guess work by the ecu but approx. 10 litres left) but would not be able to put in 55 odd litres.
I hope this makes sense.
Paul
AK996
PostPosted: Fri Oct 18, 2019 9:09 am    Post subject: Reply with quote
Unfortunately that does make sense.
Hope its not that, sounds like a big job.
I am dropping it back to the dealer next week so will definitely let him know.
There are a few other things he should be sorting out so hope he will do it properly before the car is officially handed over to me.
I will post some pics later.
Thank you
PostPosted: Fri Oct 18, 2019 7:01 pm    Post subject: Reply with quote
If you have any other issues no matter how small then please post .. this forum has a vast amount of owner experience and people here are always willing to help out .
Indy Mechanic .
AK996
PostPosted: Fri Oct 18, 2019 7:52 pm    Post subject: Reply with quote
The other things:
Air con not working, makes a noise and blows more but not cold.
Electric Passenger seat one function up/down not working, just makes clicking noise.
No CD for SAt Nav- so I do not know if it works.
Rear parking sensor works sometimes but mostly just beeps continuously.
Cracked Driver Side indicator lense.
Bonnet does not stay up after a drive, seems to stay up when cold.
Fuel gauge as mentioned.
Creaky dashboard.
I still have a week to discover more, anything I should look out for or check?
AK996
PostPosted: Fri Oct 18, 2019 7:55 pm    Post subject: Reply with quote
The other things:
Creaky dashboard.
PostPosted: Sat Oct 19, 2019 4:00 pm    Post subject: Reply with quote
A/C will make a noise when its low on gas , turn off the a/c and the noise should go. usual fault is a small leak in either the condensers or the a/c pipe connection by the o/s/r wheel .
Seat fault .. motor or cable from that motor is jammed .
Nav might not be fitted , what pcm unit do you have and what message comes up when you press the nav button ?
lens .. new one req.
Bonnet .. bonnet stays / shocks required .
Creaky dashboard .. hell a lot of different things that can be .. sound clip / video is needed to start the ball rolling there .
Indy Mechanic .
AK996
PostPosted: Mon Oct 21, 2019 8:54 am    Post subject: Reply with quote
Hi
I do not the which pcm it is but when I press the navigation button it asks to insert the CD, which the dealer says he will have ready for me.
I put the car on a friends ramp and he discovered:
Front near side
Perished bump stop
excessive play on lower ball joint
stabiliser link excessive play
Offside
excessive play on ball joint
excessive play stabiliser link
Both rear stabiliser excessive play
Break fluid had water content
Air con rads look oily?
Now I know why the car seems to jerk/slide just a bit now and then, I thought it was the hard suspension which i am not used to.
I will email the dealer to let him know but am wondering if they will actually take care of everything or let some things go and give me a new MOT.
Is it unreasonable for me to expect the dealer to rectify all this as the car is quite old?
Robertb
PostPosted: Mon Oct 21, 2019 12:05 pm    Post subject: Reply with quote
Sounds like it may need new front coffin arms (common problem), drop links (easy job) and a brake fluid change.
Personally, I'd get the car MOT'd by your usual guy. It may well fail on some of the points you've noted (excessive play on ball joints/stabilisers/droplinks) and I think you should expect to buy a car from a dealer that is roadworthy (i.e would pass an MOT at the point of sale).
I'd not worry about the perished bump stop. Some of the rubber suspension components can look a bit tatty/perished but sill work fine.
The aircon fluid may be leaking out of the condensers, hence the noise & oily residue. This means new condensers, which will be a few hundred £ at least so I'd want that sorted by the dealer if at all possible.
Get some mesh grilles fitted when the front bumper is off to protect the rads and condensers in future.
PostPosted: Mon Oct 21, 2019 7:09 pm    Post subject: Reply with quote
If it says insert cd then nav is fitted and a cd is needed to load the software ... nav disc will sort that problem.
Bump stop .. normal these days and not worth doing unless with other shock work .. garage will not fix .
Link rods and ball joint play .. that's not so good .. garage will probably dispute this .. it needs to be done if keeping the car though.
Brake fluid .. it should be done every 2 years .. i suspect that a measurement of water over the limit and its not been done in many a year .. poor maintenance i feel .
There does seem to be many problems on this car so far which is a shame .
Indy Mechanic .
AK996
PostPosted: Wed Oct 30, 2019 4:45 pm    Post subject: Reply with quote
Just an update thought it may be of interest.
Got the car back after the dealer serviced it to officially hand it over.
They did the following:
Replaced two front tyres with new continentals
New front brake pads
Two new AC radiators, blowing proper cold now
Fixed passenger electric seat issue
New strut/damper for front boot
New coffin arm driver side- driving much better.
Fixed reverse parking issue
replaced indicator lens
Gave a sat nav cd so it works now
So I am quite impressed with them.
Told me to keep an eye on the fuel tank capacity and if it did not improve then they would take it in again.
I did some research and tried the following:
Filled up to the brim(range now 230 miles gauge showing full), drove straight home and disconnected the battery for 1.5 hours. Reconnected the battery and turned on ignition for 5 minutes not the engine.
Range now 325 miles .I think the fuel sensor and fuel gauge now reading from the same book.
thumbsup
Dealer is Portiacraft.
I bought from them because they are local now I am so glad I did.
Thank you for all the replies.
Griffter
PostPosted: Thu Oct 31, 2019 10:09 am    Post subject: Reply with quote
I’m impressed by the fact that they let you take the car, compile a list of things to fix and take it back for them to be addressed before “handover”. That really is stand out service!
On a separate note, whatever happened to that guy buying a car from Glasgow which had a long list of things to be done, an even longer list of excuses and an even longer still “delivery” time?
bakerboy4s
PostPosted: Thu Oct 31, 2019 4:17 pm    Post subject: Reply with quote
I think that is a result, and well done to Portiacraft!
