997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
polar964
PostPosted: Mon Oct 14, 2019 4:56 pm    Post subject: Car cut out and now won't start Reply with quote
Hi Folks,
Hope you can shed some light please.
Took the car out today to stretch its legs! It started off the button as always, literally first turn. Ticking over sweet as a nut. Went down the road, a mile and a half tops onto a dual carriage way went to accelerate and car died and as it did the revs dropped to zero. Coasted to a halt, fortunately in a lay-by. Attempted to restart, but wouldn't fire up not even an attempt. Had a spare DME relay which I replaced, unfortunately this made no difference.
Ended up getting the recovery home.
What do you think? what shall I try next?
Thanks for reading
Paul
Paul
ras62
PostPosted: Mon Oct 14, 2019 5:11 pm    Post subject: Reply with quote
Crank position sensor the most likely culprit
polar964
PostPosted: Mon Oct 14, 2019 5:52 pm    Post subject: Reply with quote
Thanks for your reply ras62.
I was reading a post with similar issue where the CPS was mentioned, but unfortunately the OP had not indicated whether or how the issue was resolved.
Paul
Paul
polar964
PostPosted: Sat Oct 19, 2019 9:31 am    Post subject: Reply with quote
Paul
Car all sorted. It was the CPS.
Paul
