997 : 2004- 64
Robert Wildbur
PostPosted: Sun Oct 13, 2019 9:29 am    Post subject: Oil Leak Reply with quote
Just booking my car in for full service and possibly suspension overhaul, due to 19 year old 85k old rubber creaking, and have noticed I have oil misting from the back left driveshaft (no oil loss or dripping on floor), can anyone tell how much work is involved in fixing this before I book it in?
Thanks.
2000 996 3.4 Carrera 4C Cab Rainforest Green
 Filesize:  1.43 MB
 Viewed:  822 Time(s)
OldTimer
PostPosted: Mon Oct 14, 2019 2:28 pm    Post subject: Reply with quote
Cost me £130 to have a new Driveshaft oil seal fitted, though that included chiselling off the filler plug as the old one had rounded off.
From Photo looks like the CV boot has split though?
P0tential
PostPosted: Thu Oct 17, 2019 8:14 am    Post subject: Reply with quote
That CV joint boot is torn, replace it immediately before you destroy the joint! The oil you're seeing is likely from the shaft seal though. Some weeping is not uncommon, but yours looks quite bad.
996 Carrera 4 Coupe
Robert Wildbur
PostPosted: Thu Oct 17, 2019 8:55 am    Post subject: Reply with quote
Thanks for heads-up, I will not use it to I can get it booked in javascript:emoticon('Mad')
