997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
v6matt
PostPosted: Fri Oct 11, 2019 3:14 pm    Post subject: Porsche 997 Alternative Parts List Reply with quote
After spotting a post about parts that are common across cars (but not common knowledge!), and having found this previously very useful on my old Maserati. (Note: Check these parts yourself, no liability e.t.c entirely at your own risk)
Let's get the ball rolling....
Rear number plate lights are VW, I got mine from carparts4less. I think the part number was 1J6943021B (About £9 instead of £16)
switchable exhaust vacuum actuator is similar to the 996 version, Designtek fits. (Thanks robertb)
997 suspension angled bearings - I strongly suspect *but cannot confirm* they are the same as used in Fiats (50700871) Supplied by SACHS 801 035 , Lemforder e.t.c. Again about half the price of Porsche parts.
(Thanks to cannop) - Door Lock Mechanism is the same as the MK5 Golf saving £200+
OEM Porsche Bump Stops are actually cheapest from Porsche, about £14 a pop (cheaper than ECP parts), but if you are ordering from Autodoc then they do the FAG 811 0098 30 (2x dust covers and 2x bump stops for £16)
OEM Tie Rod Ends are TRW JTE760 Gen 1 & 2
OEM Inner Tie Rods are TRW JAR1041 Gen 1 & 2
OEM Waterpump is a Pierburg 7.28015.02.0 Gen 1
OEM coilpacks are Beru ZS178 Gen 1
OEM sparkplugs are Bosch FGR5KQE0 Gen 1
OEM 997.1 tandem pump is a pierburg 7.00264.02.0 (Thanks Phil 997)
OEM 997.2 tandem pump is a pierburg 7.02388.18.0
Other ideas, but not a direct swap for original
(Thanks Hertsdriver) Eibach Pro lowering spring kit for PASM 997.1 has the part number E10-72-007-01-22, you can buy the springs separately a lot cheaper than buying the kit:
Front springs: 117200701VA
Rear springs: 117200701HA
2008 Carrera 4 - Gen 1 997
v6matt
PostPosted: Tue Oct 29, 2019 6:20 pm    Post subject: Reply with quote
No interest in an alternative part list? Maybe it would help if it was a sticky so it doesn't vanish after a day.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Oct 29, 2019 6:33 pm    Post subject: Reply with quote
Looks like a very helpful thread... it would be interesting to know if there is much 996 crossover too.
I know for example the switchable exhaust vacuum actuator is the same for both, and the £50 Designtek version fits, with a little modification.
Jam911
PostPosted: Tue Oct 29, 2019 7:10 pm    Post subject: Reply with quote
We need to merge this with the posts about door parts from a few weeks back.
Alternative Parts List is perfect sticky me thinks
Current '07 997 C4S
Ex '99 2.5 Boxster
DucatiRob
PostPosted: Tue Oct 29, 2019 9:50 pm    Post subject: Reply with quote
I think it's a great idea Thumb suggested it myself sometime ago! We have a similar thread on my Ducati forum, surprising how many parts are common to other vehicles! Good idea about the sticky too Thumb
Mercedes CLK DD
Ducati 996
Sondergard
PostPosted: Tue Oct 29, 2019 10:37 pm    Post subject: Reply with quote
Thats great - Im a newbie and I would love a list like this.
Unfortnately I dont have much information of parts to add.
worship
997.1 Carrera S Tiptronic
monster
PostPosted: Wed Oct 30, 2019 1:21 am    Post subject: Reply with quote
Yes its a great idea. Another shout for making it a Sticky!
PostPosted: Wed Oct 30, 2019 8:20 am    Post subject: Reply with quote
997.1 tandem pump is a pierburg 7.00264.02.0 Thumb
currently best price is frazerparts at£294 inc vat.. previous best price was at autodoc.
good idea for a sticky
Captain Lockheed
PostPosted: Wed Oct 30, 2019 8:42 pm    Post subject: Reply with quote
Great.
Another vote for a sticky.
Saving for a 993.
v6matt
PostPosted: Thu Oct 31, 2019 11:52 am    Post subject: Reply with quote
Great to see there is some love for the idea,
I have just updated a couple of the new lines into the master
PostPosted: Thu Oct 31, 2019 12:08 pm    Post subject: Reply with quote
Matt,
911admin don't read all the posts so suggest you drop either admin or one of the mods a PM about getting it made a sticky as they may miss the request, and to me it seems like a reasonable thread to have as a sticky. as saving money on parts is quite close to most 997 owners hearts Thumb
v6matt
PostPosted: Thu Oct 31, 2019 12:12 pm    Post subject: Reply with quote
Phil 997 wrote:
Matt,
Done worship
Thefinn
PostPosted: Fri Nov 01, 2019 1:15 pm    Post subject: Reply with quote
not sure that this is going to be the best help but i was able to swap out a broken window motor for a part off an Audi A3 which saved me the best part of £100 for a second hand part. You need to re-use most of the unit i.e. the regulator and controller part but the motor itself just unscrews and swaps
you will need to check the numbers on the motor as they are all different for each model car / which side i think but if its just the motor that's gone use that part number rather than the whole unit
997.1 C4S CAB
FZP
Estoril
PostPosted: Fri Nov 01, 2019 2:37 pm    Post subject: Reply with quote
Great thread Matt. I agree, this needs to be a sticky one as can only be a good thing.
Out of curiosity, the switch in my door handle(The one that makes the window drop and raise) has gone on mine and I've not even had the chance to look for the OEM part, let alone a same/same for the OE. If someone has that it would be appreciated Thumb
Keep up the good work
Captain Lockheed
PostPosted: Sun Nov 03, 2019 6:47 pm    Post subject: Reply with quote
Microswitch Power windows
997 613 125 02
Saving for a 993.
FZP
Estoril
PostPosted: Sun Nov 03, 2019 8:46 pm    Post subject: Reply with quote
Thumb thanks for that
systech1
PostPosted: Mon Nov 04, 2019 12:31 am    Post subject: Suggestion... Reply with quote
I fully support this idea and it being made a sticky.
Just one suggestion though...as there are some differences between 997.1 and 997.2, can contributors please indicate which is relevant (or both If applicable) and if possible the OEM PN(s) which is being replaced?
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, DSC PASM controller, Carrera Sports wheels, Ducktail/Diffuser and splitter, Sport Design steering wheel etc.)
Billy Bumpsteer
PostPosted: Mon Nov 04, 2019 8:07 am    Post subject: Reply with quote
Something like?
PostPosted: Tue Nov 05, 2019 3:33 pm    Post subject: Reply with quote
Some may find this interesting . Do you want front grilles but dont like the front fitting zunsport ones and dont want to pay porsche tax for OE rear fitted ones . Have a look at these rear fitted grilles they seem like a good product at a fair price.
https://www.radiatorgrillstore.com
v6matt
PostPosted: Thu Nov 14, 2019 4:20 pm    Post subject: Reply with quote
Billy Bumpsteer wrote:
Something like?
I just updated the list with these details Thumb
