991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
alpinaB3
PostPosted: Wed Oct 09, 2019 9:26 am    Post subject: Trim Removal - between the dashboard and door frame? Reply with quote
I am needing to remove the plastic fill-in trim that fills the gap between the right hand side of the dashboard and the drivers door frame (as highlighted in the pic).
It looks like that I need to remove the rubber door seal first, is this just pushed on or is is glued to the metal door frame?
Current: 911.2 4S, Sapphire Blue Metallic, Graphite Blue leather interior, Manual transmission, Rear-axle steering, Sport Suspension, Sport exhaust, 18 way Sport Plus seats, Sport Chrono Package, BOSE® Surround Sound-System + other goodies!
Past: Alpina B3 BiTurbo Coupe (e92) No.268 of 270
http://carscapes.byethost33.com/
 Filesize:  539.04 KB
 Viewed:  338 Time(s)
fnumber1user
PostPosted: Wed Oct 09, 2019 11:39 am    Post subject: Reply with quote
Not 100% but seem to remember that if you ease the door shut rubber off from where it sits, that plastic panel comes out from it's front edge (ie where the rubber was previously).
It shouldn't be glued - and is just an interference (push) fit.
HTH?
