997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
Matrixxxx
PostPosted: Tue Oct 08, 2019 8:38 pm    Post subject: Cayenne 2009 GTS hesitation on light acceleration Reply with quote
Well, to add to my list of problems, after changing the thermostat and a new set of plugs, and fixing the vacuum leak, the hesitation is still there.
But!! If I switch off the "PSM" it runs perfect!??, runs as if in sport mode holds the gears longer but no hesitation and pulls a lot more when accelerating,
when you switch it back on the revs drop and it become sluggish and hesitates.
just wonder if it is related to the faulty signal from the front acceleration sensor?
Matrixxxx
PostPosted: Sun Oct 13, 2019 9:26 pm    Post subject: Reply with quote
Now realise that psm keeps the revs above 2k , the hesitation seems to be below 2k rpm.
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
CarraraWhite
2011 Porsche 991 Carrera
PostPosted: Mon Oct 14, 2019 11:14 am    Post subject: Reply with quote
What garage are you using ?
did they plug in the diagnostics machine
991Turbo, dont need the S
crash7
PostPosted: Mon Oct 14, 2019 11:20 am    Post subject: Reply with quote
When were the coils last changed?
Are you getting a CEL?
Billy Bumpsteer
PostPosted: Mon Oct 14, 2019 12:37 pm    Post subject: Reply with quote
Coil packs would be my guess
Matrixxxx
PostPosted: Mon Oct 14, 2019 12:40 pm    Post subject: Reply with quote
I bought an icarsoft scanner, just put a new acceleration sensor in, still hesitating, I do all my own work.
Im sure the coils have been changed at some point, it is looking like they may need changing.
crash7
PostPosted: Mon Oct 14, 2019 1:37 pm    Post subject: Reply with quote
I had a similar problem on my 58 GTS.
Intermittent hesitation under light throttle, no CEL.
I lived with it and eventually the car through up a CEL, which would reset everytime you turned the car off and not come up every journey, I carried my scanner in the car and eventually caught it, codes indicated a coil fault on cylinder 2.
Changed the coil(s), problem solved.
Good luck.
Matrixxxx
PostPosted: Mon Oct 14, 2019 2:03 pm    Post subject: Reply with quote
Did the bad coil look ok? I didn't see any cracks when changing the plugs, I would assume that they all are not failing. May buy one and swap it around.
crash7
PostPosted: Mon Oct 14, 2019 2:28 pm    Post subject: Reply with quote
No, no visible signs of any wear or damage.
I only had a fault with one, but given they were all the same age and original to the car I replaced them all as a matter of course, however as you say it may not be necessary.
Billy Bumpsteer
PostPosted: Mon Oct 14, 2019 2:47 pm    Post subject: Reply with quote
A Durametric will certainly pick up the faults even if it hasnt thrown a full CEL, I take it the icarsoft didnt show up anything?
Matrixxxx
PostPosted: Mon Oct 14, 2019 3:42 pm    Post subject: Reply with quote
It hasn't thrown any faults, but can see a lot of variables, I guess it should be possible to see something not running as the rest. How long do they normally last?
Billy Bumpsteer
PostPosted: Mon Oct 14, 2019 3:55 pm    Post subject: Reply with quote
They can last 10 years or 6 months. I changed all mine and 6 months later the exact symptoms you have showed again, Durametric showed cylinder 5 missing, just changed that one that time and all ok 12 months on, get it plugged into a decent machine and it will tell you the cylinder/cylinders missing
Matrixxxx
PostPosted: Tue Oct 15, 2019 10:58 am    Post subject: Reply with quote
ordered a full set.
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
Matrixxxx
PostPosted: Tue Oct 15, 2019 11:26 am    Post subject: Reply with quote
Old and new sensor
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
 Filesize:  221.04 KB
 Viewed:  2473 Time(s)
New, part number for reference.
 Filesize:  268.46 KB
Old sensor, the potting had cracked.
 Filesize:  202.62 KB
Matrixxxx
PostPosted: Thu Oct 24, 2019 11:31 am    Post subject: Reply with quote
fitted the coils, it drives differently, more torque, quieter and smoother, while playing with the scanner after 10minuites or so there was a noise like the cd player loading a disk over and over, turned the head unit of but it was still going, now I think it was the throttle recalibrating its self.
it now holds the higher gears , if you accelerate slowly it will pull along in top gear, before it would not do anything then jump down 2 gears, there is still slight juddering but it doesn't feel like a misfire. will leave if for a few weeks for everything to settle down.
got all the coil packs for under £180 off eBay.
I am also wondering if the ignition module was in the water that was trapped in the bulkhead/firewall.
PostPosted: Thu Oct 24, 2019 7:55 pm    Post subject: Reply with quote
Throttle will recalibrate if needed with ign on .. it won't happen when driving and it it needs to do this find the end stops so i doubt that is an issue ... end stops being it doesn't know full open / full closed .
New coils and it drives better would indicate x1 coil was breaking down .. but is fixed .
The box adjusts to the driver .. so if you stamp on the throttle a few times while driving then it will adapt to a faster gear change .. ie instead of x1 down shift it will do x2 .
What we call granny mode .. the car thinks everything is lazy and slow and so it will perform that way .. boot it a lot / fast stamp on the throttle and it will go into sport mode in essence .
PSM fault will have an impact but on the suspension not the engine .. well to a degree .. it can feel similar though .
Drive it .. boot it and see how it goes then report back i feel .
Indy Mechanic .
Matrixxxx
PostPosted: Wed Nov 13, 2019 12:27 pm    Post subject: Reply with quote
A few weeks now, it now feels like it did before sluggish and jerky on light acceleration, seems to be worse when raining?
will do a smoke test soon to see if there is still a vacuum leak somewhere.
but it runs well when you boot it, smooth reving , slick gear change, sounds great, unfortunately I spend 95% of my driving in the 1000-2000rpm range where the hesitation is, but only on light acceleration once up to speed its very smooth and stable.
one of the aftermarket HID's blew, so had to fit a pair of HID bulbs from a kit someone gave me, but the output was very dim and blue, so fitted some LED Beamthech units , had to order an adaptor, seem good , just as bright as the HID's before, good solid beam pattern, and no ballast hanging out of the back of the light.
but now need to get load resistors to stop the "Check low beam " warning.
you could use these for main beam as there is no switch on delay or surge?
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
MarkGolf
PostPosted: Wed Nov 13, 2019 12:45 pm    Post subject: Reply with quote
In regard to jerkiness, do you think it is definitely the engine being jerky or do you feel it through the car?
I had some jerky/pulsating feeling at 2000rpm which turned out to be having different brand of tyres on the rear. That feeling came back on the weekend and it was due to a tyre being 20 psi..
If it's engine, are any of your plugs oily?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Matrixxxx
PostPosted: Wed Nov 13, 2019 4:26 pm    Post subject: Reply with quote
the jerkiness is from the engine when accelerating, the whole car judders very briefly, could it be engine mounts ( not the top one) ?
Plugs were all oil free.
it has had the high pressure fuel pump fitted in the past, this could also cause my issues. seems common on the Panamera.
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
PostPosted: Wed Nov 13, 2019 8:32 pm    Post subject: Reply with quote
Just a wild stab in the dark but possible it's a transfer case issue .. they do give similar faults ..
A garage with experience of these issues needs to drive the car to be honest .. i kinda know what it feels like but obviously i can't drive your car so just a suggestion .
Indy Mechanic .
