997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
portreathbeach
PostPosted: Tue Oct 08, 2019 8:33 pm    Post subject: Oil pressure question Reply with quote
I've had my 2004 Carrera S for a month now and the oil pressure was always between 4 and 5 even on tick over. Most of the time it was up around 5.
Anyway, tonight I took the car out for a blast and now the oil pressure seems to be around 3 at tick over and goes up and down depending on revs. This is kind of what I would have expected it to do all along.
Anyone have any idea what is going on, or what was going on before?
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Tue Oct 08, 2019 8:47 pm    Post subject: Reply with quote
tick over should be circa 1.5 bar
so might have a sensor fault, worth getting a Porsche diagnostic machine check
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
portreathbeach
PostPosted: Tue Oct 08, 2019 9:07 pm    Post subject: Reply with quote
It's really the first time I've driven it fairly hard, and kept the revs up in Sport mode. Just wondering if it's only been up around 5 bar most of the times I've driven it before because the engine was cooler. Although all the times I've driven it before, I have had the engine temp at 80C and the Oil at 90C.
Will have to see what it's like tomorrow.
kurlykris
PostPosted: Tue Oct 08, 2019 9:23 pm    Post subject: Reply with quote
With the ignition on ( engine not started ) the oil pressure should be 0 Bar, hot engine and the pressure should be 1-1.5 Bar at tickover and rise with an increase in revs all the way up to 4-5 Bar at full chat, sounds like you may have a dodgy oil pressure sender unit Question
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
portreathbeach
PostPosted: Tue Oct 08, 2019 9:55 pm    Post subject: Reply with quote
Thanks kurlykris.
I’ll check out exactly what it’s doing tomorrow.
I just had a look online at changing the sensor. Doesn’t look too tricky, just need a 19mm crow foot spanner by the looks of it.
If the sensor is faulty, should it be replaced with an original Porsche one, or is the cheaper Bosch one just as good?
kurlykris
PostPosted: Tue Oct 08, 2019 10:14 pm    Post subject: Reply with quote
Obviously Porsche don`t actually make the sender unit themselves, it`s probably Bosch, so GSF or ECP or your local car parts place can get the same thing but much cheaper Grin
Just make sure that the oil pressure guage reads 0 without the engine running and ignition turned on, if it doesn`t then it is no good.
A 10 mile drive max will see the engine coolant and oil up to operating temp and at tickover should be 1-1.5 Bar Thumb
portreathbeach
PostPosted: Wed Oct 09, 2019 9:07 pm    Post subject: Reply with quote
OK.
If I put the keys in and turn on the car (not start the engine), the oil pressure reads about 0.5 bar. (A couple of times it read 2 bar).
When the engine and oil are up to temperature, the gauge reads 5 bar most of the time unless at idle, where it drops to 3.5 - 4 bar.
Does this sound like the pressure sensor needs replacing?
If the oil pressure sensor needs replacing, is this the one I need for a 2004 997.1...
https://www.design911.com/Porsche/997-MKI--911--2005--08/Oil-Pressure-Senders---Switches/pt856_859_2373_-cma81-cmo117/
kurlykris
PostPosted: Wed Oct 09, 2019 9:24 pm    Post subject: Reply with quote
Yes ignition on, and engine not running, the oil pressure should always be 0 Thumb
Yes your link looks like the correct unit, the part number 99660620303 looks to have superseded the older 301 and 302 part numbers.
portreathbeach
PostPosted: Thu Oct 10, 2019 9:01 pm    Post subject: Reply with quote
Turned the ignition on today and the oil pressure read 2 bar without the car running. I think the sensor is definitely defective.
A the car is going in for a major service in a couple of weeks time, the garage have ordered a sensor on a sale/return, so they can test the old one and fit the new one if required.
bazhart
Approved Trader
PostPosted: Fri Oct 11, 2019 4:30 am    Post subject: Reply with quote
The condition you describe is often caused by a small piece of debris material getting stuck in the hole leading into the sensor and holding some pressure inside it even when the engine has stopped.
New sensor will probably fix it.
Baz
Click here for the Hartech
www.hartech.org
PostPosted: Fri Oct 11, 2019 7:19 pm    Post subject: Reply with quote
Agree
Pretty common and 95% of the time it's a new sender unit that's required .
portreathbeach
PostPosted: Tue Oct 29, 2019 6:57 pm    Post subject: Reply with quote
The mechanic that serviced my car changed the pressure sender and now it works fine. Very Happy
bullet-proof_biscuit
PostPosted: Wed Oct 30, 2019 3:01 pm    Post subject: Reply with quote
Hello,
I have intermittent reading faults, when very hot oil and idling the gauge sometimes stays at 3-4 bar, and I know this can't be right because it normally drops to just over 1 bar when very hot idle, but it happens so infrequently I think it's all in my head and I'm going mad, assume this is early sender failure symptoms? I will swap now thanks to this thread.
Related; lately my oil temp gauge drops to 60 degrees for a few seconds and comes back up, I panicked and thought this could be low oil meaning the sender was exposed but pressure was good (gauge said good..), can the combined temp/level sender start to fail and give spurious readings?
Seems like it's a manifold off job to replace the long sender.... That's early M97 though and even though my car is 2004 it has had a later large IMS bearing engine fitted, and not sure if the sender is in a different / easier access position.
