997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Tombri
PostPosted: Tue Oct 08, 2019 1:25 pm    Post subject: BANG - no rear screen. Reply with quote
Driving along on the west coast of Scotland near Oban last Sunday morning when there was a loud bang. Looking in the rear view mirror showed the rear screen totally shattered.
It had been wet and the car was misted up but the rear screen demister was working a treat. The last time I switched it on I must have left it on for a few minutes after the screen had demisted for a few minutes and then the screen went a minute or so after I switched it off.
I suspect the rear screen was the original one but does anyone know why this might have happened?
It had the third brake light fitted at the top of the screen. Will I need to get a new set of fixings and will is Mr Autoglass likely to know how to fit it or is that out with his job spec? Question
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
PostPosted: Tue Oct 08, 2019 1:55 pm    Post subject: Reply with quote
It's not uncommon for this to happen in air-cooled and might be a factor of ageing glass and a rear demister element that has the ability to melt cheese. Confused
Good opportunity to have a look under the surround when it comes out and despite what some may say I've met a few mainstream glass fitters who have experience of working on older cars and know some of the issues.
I think when the rear spoiler/brake light comes off you can secure the reatining brackets back down with double sided tape although I do believe OPC supply the kit.
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
Tombri
PostPosted: Tue Oct 08, 2019 2:04 pm    Post subject: Reply with quote
Thanks Zingari - I reckon the cause must have been the combination as you say.
I do have a £1 size of 'bubbling' on the scuttle so a good chance to get that repaired and an inspection of the rest.
Would you think double sided tape would be better/as good as an epoxy glue...? Nervous about pressure washing/rain etc could make the tape come unstuck.
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
MidWansbeck
PostPosted: Tue Oct 08, 2019 9:57 pm    Post subject: Reply with quote
Here are the shots...
Adapt, improvise and overcome...
964 C4 Coupe and Gutbrod 1032
 Filesize:  210.27 KB
 Viewed:  2527 Time(s)
 Filesize:  310.81 KB
Hamster75
PostPosted: Tue Oct 08, 2019 11:19 pm    Post subject: Reply with quote
Its amazing bang when they go, I had a new BMW sunroof explode last year during the hot summer, it blew when I opened it electronically then expanded & bang, the dealer & BMW UK wouldn't fix it under warranty they said it must have been hit by grit or a small stone previously, bollox it was due to temperature.
They happen all over the world in hot & cold climates Canada & Texas are often the case.
Funny thing was when I paid through insurance £1000 + for the new unit it was a thicker different glass.
I would say a temperature change has done yours Question
991.1 C2S Red
997.2 C4 White
924 Blue
ToreB
Approved Trader
PostPosted: Wed Oct 09, 2019 5:43 am    Post subject: Reply with quote
Tempered glass can fail due to many reasons, and it is quite dramatic when it happens. There has been numerous rear glass damages after short circuits in the third brake lighting wiring, discussed several times on the Rennlist forums. The third brake light wires are printed on the glass, just like the heater wiring. A short circuit will build up a lot of heat on one spot, causing the glass to shatter.
In short, if you have the window-mounted third brake light, check the wiring, if you don't have it, disconnect the wiring to the light under the rear shelf.
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
Tombri
PostPosted: Wed Oct 09, 2019 8:07 am    Post subject: Reply with quote
Thanks Tore.
When I took the outer rubber off the screen I could see there was a bit of water in the channels around the screen, so maybe this is the problem. This is where there was bit of corrosion.
There seemed to be 3 wires attached to the bottom of the screen. Would 2 be for the heater element and the other for the 3rd brake light? If so which one is the brake light wire?
I have upgraded the 3rd brake light with your wonderful HID upgrade and I definitely want it reinstalled. Should I get it rewired?
Cheers.
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
ToreB
Approved Trader
PostPosted: Wed Oct 09, 2019 8:29 am    Post subject: Reply with quote
Info here: https://p-car.com/diy/glass/
Cheers,
Tore
'95 993 C4
Bergvill F/X
hot66
PostPosted: Wed Oct 09, 2019 9:09 am    Post subject: Reply with quote
sorry to hear about the rear screen ... but that interior looks stunning thumbsup . Black car with red in one of my favorite combos thumbsup
James
1973 2.4S
1993 964 C2
gone :
1967 2.0 SWB 911
1995 993 C4 Cabrio
2003 996 Turbo DMS
2003 M3 CSL
DDK
Tombri
PostPosted: Wed Oct 09, 2019 9:29 am    Post subject: Reply with quote
Thanks James - I think it is called Flamenco red.
Many years ago I had a white 944 turbo with red can can interior which was a bit 'in your face', but suited the 80's Dance
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
Tombri
PostPosted: Wed Oct 09, 2019 9:33 am    Post subject: Reply with quote
Thank you very much Tore.
You are a Norwegian legend. Thumb
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
harryk
PostPosted: Thu Oct 10, 2019 9:56 am    Post subject: Reply with quote
Black with Flamenco, just like mine! Love it: it's what drew me to buying my car.
1995 993 C4 Coupe. Schwartz/Flamenco Red soft nappa leather. Exclusive leather everything, Exclusive extended centre console, MO33 suspension set up by CG, Chipwizards 287bhp remap, FDM Goldenrod & SSK, Techart exhaust, Techart pedal set, Tequipment dials, Tequipment handbrake & gearlever.
Instagram @hskular
Tombri
PostPosted: Thu Oct 10, 2019 1:23 pm    Post subject: Reply with quote
Those are some great mods HarryK.
Do you have any photos of the interior and dials?
worship
Golf GTi
Golf R - Sold
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
harryk
PostPosted: Fri Oct 11, 2019 7:25 pm    Post subject: Reply with quote
There are a few on my Instagram @hskular
On dad duties so I have 10 seconds to write this!
Instagram @hskular
Normski298
PostPosted: Thu Oct 24, 2019 6:20 pm    Post subject: Reply with quote
I had exactly the same thing happen to me in my c4 last year - first day of our drive down to the south of France.
993 C4 Schwarz Perl
_____________________
1999 Mercedes C43 AMG
Previously:
993 C2 manual Guards Red
993 Targa Midnight Blue
 Filesize:  53.84 KB
 Viewed:  1591 Time(s)
pzero
PostPosted: Thu Oct 24, 2019 6:39 pm    Post subject: Reply with quote
Some further discussion here;
http://www.911uk.com/viewtopic.php?p=911507
991.1 Carrera GTS
