991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
MattEd
PostPosted: Tue Oct 08, 2019 10:51 am    Post subject: Xenon Headlight Bulbs Reply with quote
One of my bi-xenon headlight bulbs has gone and I'm having trouble finding a replacement.
It is a Philips Xenon DLS 25W.
Does anyone know how i can get hold of one? Or is there an alternative that fits?
It's a 981 Boxster S.
Matt
easternjets
Watkins Glen
PostPosted: Tue Oct 08, 2019 11:14 am    Post subject: Reply with quote
If it's the ones I think your after then Design 911 have them.
I bought two because one of my bulbs was playing up but I found when I went to change if that there was a loose connection, so remove your headlamp unit and check that everything's tight. Easy to get out but a bit of knack to refitting unit.
They're about £60 + vat a pair
https://www.design911.co.uk/fu/pt70_196_535_-cma81-cmo82-ct288/Porsche/Boxster-986-987-981/Boxster-986-27L-1999-02/Dipped-Low-Beam-Bulbs/
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
MattEd
PostPosted: Tue Oct 08, 2019 11:27 am    Post subject: Reply with quote
Thanks, I've taken it out and put back but still not working so I guess the bulb has gone, although it still looks like its ok, no discolouring or anything...
The bulb you have linked to doesn't have the base part on it, see attachment. When I had the bulb out it didn't seem to be detachable from the base and the warning message suggests that they're not separable. Is it possible to separate them?
Matt
[/img]
 Filesize:  77.05 KB
 Viewed:  482 Time(s)
easternjets
Watkins Glen
PostPosted: Tue Oct 08, 2019 11:39 am    Post subject: Reply with quote
Yes they detach from the bulb, there is a vid on You Tube showing how to dismantle them, quite easy when you see the vid.
997 Turbo Gen 2
Porsche 928 S4
MattEd
PostPosted: Tue Oct 08, 2019 12:05 pm    Post subject: Reply with quote
Ok, thanks. I'll have to check that the bulb looks the same, as my base says DLS and those bulbs say D2S, so may not fit.
I've got a feeling this is a dealer only replacement, so will cost about £150 just to change a light bulb nooo
easternjets
Watkins Glen
PostPosted: Tue Oct 08, 2019 2:04 pm    Post subject: Reply with quote
No it's a DIY job, don't need to go to dealer.
997 Turbo Gen 2
Porsche 928 S4
