991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
911Time
PostPosted: Mon Oct 07, 2019 5:37 pm    Post subject: How to Replace 991 Cabin / Pollen Filter and Best Price Reply with quote
Hi all,
Having returned from our epic Highland adventure, I noticed that despite cleaning the windows before coming home, a film was beginning to form again on the inside of the windscreen.
Whenever this starts to happen more frequently, I think it's always worth checking whether the cabin/pollen filters are blocked and sure enough the cabin filter (located in the boot) looked in need of a change.
It's a pretty easy DIY job, not something you need to head to a dealer for, so you can save yourself money on labour/parts.
Anyway, here's a how-to guide and some info on where you can buy the parts at a good price:
Filter One
Filter one is fitted in the front, beneath the battery compartment cover. You don't need any tools for this - just a clean cloth and a vacuum, to remove any dirt/debris.
1: Open the boot and remove the battery cover by carefully lifting the cover and pulling upwards on the two recesses (see arrows) - slide the cover forwards slightly and you will see that it's located at the back edge on two yellow supports (when you refit, slide the cover back into place on these supports first before you press down the front and you will hear it click back into place).
2: On RHD cars the airbox for the heater is located on the back right-hand side - to the right of the battery.
3: The top is held in place by plastic clips, working from front to back, simply push the head of each clip away from the centre of the top (right or left) with one hand, whilst lifting the top slightly with the other. You don't need to remove the top completely, as the filter can be removed with the top of the housing just lifted at the front.
4: The filter sits in some plastic slides/grooves and forms a 90 degree angle within the filter housing and can be removed by simply lifting at the front and sliding out. NOTE: Before removing completely, note that with the wording printed on the filter there is an ARROW, which shows the direction of airflow - the TIP of the ARROW should be pointing towards the BACK of the filter housing and the TOP of the printed filter lettering should be towards the FRONT of the car.
If you replace your filter with a Porsche item this should be the same when refitting but if you use an OEM equivalent there may be no arrow, just the lettering.
5: The replacement filter is Porsche Part No: 991.572.371.00 - MANN Filter Part No: CU 30 004 - the OEM MANN filter is exactly the same, as you can see.
6: Old and New filters.
7: Before fitting the new filter, wipe clean the inside of the airbox and vacuum out any dust/debris from beneath the airbox, which might clog the new filter.
8: With the top of the lettering on the new filter facing the front of the car (as explained earlier), slide the filter down carefully into the slides in the airbox - pushing it all the way home until the back of the filter reaches the back of the airbox (this will concertina the filter slightly, so you may need to hold the back of the filter in place with one hand, whilst pulling the top of the filter back up a bit at the front, so it covers all the opening in the airbox).
9: Refit the lid of the airbox and battery cover, as described above. Despite the explanation here, it's a 5 - 10 minute job in reality.
One down, one to go Smile
Filter Two
The second (activated carbon) filter is fitted in the passenger side footwell, behind the glovebox. For this you will need a torch and a stubby, large head (wide), slot type (straight) screwdriver OR a 90 degree screwdriver or wide screwdriver bit/ratchet, as for some of the screws there's not enough space to use a full-size screwdriver.
1: Laying beneath the glovebox and looking up, you will see a foam cover, held in place with large black plastic screws.
2: Remove the screws from the front (closest to you) and middle of the foam cover, being careful not to damage them as they are only plastic and finally remove the rear-most screws (you don't actually need to remove the ones by the carpet, as it's possible to carefully bend the foam down out of the way).
3: With the foam out of the way or pressed down, you will see the plastic housing containing the pollen filter. On the left side there are three clips which hold the door closed and the door is hinged on the other side.
4: Simply pop open the three clips on the left and the door will open downwards, at which point the filter will drop down but do not remove it yet!
5: Before removing the filter note the direction of airflow (shown on the bottom of the filter) - the arrow should be pointing towards the hinge.
6: Holding the foam cover down, pull the old filter downwards and out of the filter housing.
7: The replacement filter is Porsche Part No: 991.573.623.00 - MANN Filter Part No: CUK 25 006
8: When fitting the new filter, you will have feed the leading back edge of the new filter into the filter housing first (ensuring you have the airflow direction correct, with the arrow pointing towards the hinge) before getting the rest of the filter into place. Be careful but don't worry too much if you have to squash the filter a little, it will pop back into place when it's in the housing.
9) Finally, refit the door on the housing, refit the foam cover with the plastic screws, being sure to press the foam back into place around the courtesy light surround etc
Job done!! Thumb
Best Prices
The best prices I found for OEM quality filters were from Autodoc in Germany:
Filter One
at £9.04 incl VAT, instead of £12 - 25 elsewhere!
https://www.autodoc.co.uk/mann-filter/7015659?search=MANN-FILTER%20Filter,%20interior%20air%20%20(CU%2030%20004)
Filter Two
at £31.46 incl VAT, instead of £70 - 90 elsewhere!!
https://www.autodoc.co.uk/mann-filter/7004853?search=MANN-FILTER%20Filter,%20interior%20air%20%20(CUK%2025%20006)
In fact, the price of both filters, including delivery from Autodoc in Berlin, came to less than the price of the pollen filter alone in the UK.
Hope that helps Smile
PS: A massive THANKS to my good friend Peter, for getting into the passenger footwell to fit the new pollen filter, saving my back and crumbly bones - cheers mate!! Thumb
Mark
I'm not a perfectionist - I just want everything done 'Right' Wink
Current: GT Silver 991.1 C4S with a few 'special bits'. Previous: C63 Estate, BMW e92 330d Coupe (700Nm/Custom Exh/Map/BBK/Quaife/Breytons), ML63AMG, Alpina e46 B3S Coupe, Alpina e36 B3 Coupe, Lotus Excel SE, Alfasud Green Cloverleaf Ti, Lancia HPE, Capri 2.0S, Marina 1.8 (don't laugh it was my first road car) plus boring company cars. Bikes: Suzuki TL1000R and BMW R1100S AC Schnitzer.
Jungle650
PostPosted: Fri Oct 11, 2019 6:18 am    Post subject: Reply with quote
Thanks for taking the time to post @911Time. Will make a handy future guide.
Regds
Jungle. thumbsup
991.1 C4S
Full Xpel Ultimate PPF
And loving it !!
911Time
PostPosted: Fri Oct 11, 2019 6:30 am    Post subject: Reply with quote
Thanks Jungle - if only I'd started doing this years ago I could have had a fortune like Haynes Very Happy
Mark
PostPosted: Fri Oct 11, 2019 6:59 pm    Post subject: Reply with quote
A very well presented post which to be honest knocks spots off the rubbish i post !!
i enjoyed reading and looking at the images and i have done this many times .. mind you i might just be a sad old git lol .
yellow strap holds the front panel up , it clips onto the bonnet.
Inside pollen filter plastic " screws " .. they are a awkward .. the screwdriver slot is just not deep enough and the back right one is a pain as well ..
Mind you so is working upside down !
Very useful post though imho Thumb
911Time
PostPosted: Fri Oct 11, 2019 7:38 pm    Post subject: Reply with quote
Thank you!! High praise indeed from someone with your vast experience of Porsche Thumb
I never bother to use the yellow strap on the battery cover and only ever remember it afterwards Rolling Eyes
The plastic screws and foam cover are a poor design and even at 6 years old, both the screws and foam on mine were showing signs of damage from previous attempts to remove/refit them.
Yeah, working upside down is fine when you're young but not so clever when you get older nooo
Mark
PostPosted: Fri Oct 11, 2019 7:43 pm    Post subject: Reply with quote
These cars are starting to come into the diy sector so posts like yours are gold dust for the future , please keep posting as you go as people explaining things like this are what makes this forum the best imho .
