991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
d6ssa
PostPosted: Mon Oct 07, 2019 10:34 am    Post subject: 1988 911 Coupe sunroof Noisy Reply with quote
I have a 1988 Carrera Coupe & the sunroof is clicking in operation when it is at the end of operation opening & closing seem like the motor is continuing, I have changed the runners & cables which helped a bit, any ideas would be helpful.
PostPosted: Mon Oct 07, 2019 2:33 pm    Post subject: Reply with quote
Usually the motor continues to run as long as you have your finger on the button even after it has fully opened/closed.
Have you replaced the switch or does it need a new one?
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
