991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
darkhorse
PostPosted: Sun Oct 06, 2019 11:34 am    Post subject: 997/996 ignition coil connectors (for loom) ? Reply with quote
Posted a thread for this as I cant find any information on it. I have found one of my coil connectors (from the wiring loom) has some heat damage.meltage to the plug end (coil heat shield was a bit worse for wear) and another one has the locking clip missing. They both worked fine but I want to repin new ones on there.
I am going to phone the OPC tomorrow, just wondering if anyone knows what connectors will fit? 3 pin BERU connector to fit coils like this...
https://www.design911.co.uk/fu/pt178_1737_-cma81-cmo117-ct343/Porsche/997-MKI--911--2005--08/997-TURBO-2005--/Ignition-Coils/
I'm hopeful Porsche can supply them and I have heard they may do, but usually things like this are available elsehwere as they appear to be the same on some mercedes coils (yes I would get them from Merc if I had to as they sell the connectors). I cant find any connectors in the 911 parts pdfs I have... wondering if they say you need a loom!
Anyway, any info appreciated. Cheers
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Oct 06, 2019 12:26 pm    Post subject: Reply with quote
I bought a crimp tool to do my knock sensors on my 944 as they had turned to dust being 30 + years old. I got the correct plug and crimp connections from ebay.
There was another thread recently that discussed a MAF connector plug rewiring and connector plug. http://911uk.com/viewtopic.php?t=135264
Porsche usually only sell complete looms?
P9XX
PostPosted: Sun Oct 06, 2019 5:18 pm    Post subject: Reply with quote
I don't think Porsche will sell a single plug but would advise a new harness.
The MAF connector plug mentioned by infrasilver was bought on ebay from the following seller. The link to 3 pin plugs from this seller is:-
https://www.ebay.co.uk/str/Auto-Click-UK/3-WAY/_i.html?_storecat=27778825016
They have 108 plugs to choose from.
Good luck and let us know if you find the correct one.
2008 997.2 C2S PDK Basalt Black
darkhorse
PostPosted: Sun Oct 06, 2019 6:25 pm    Post subject: Reply with quote
Thanks, I have the tools just no connectors as yet **yes, I have now**! Will find out off OPC but I have been told they sell the loom only.. could be a load of rubbish though. Will soon find out as going to ask them tomorrow!
P9XX//
Thanks for the link, that is awesome! I have found what I think are the connectors and ordered a couple. Will update if they fit either way but they look identical. Really big help because I spent ages on ebay and came up with nothing!
darkhorse
https://www.ebay.co.uk/itm/BOSCH-1928403110-1928404073-3-WAY-CONNECTOR-KIT-INC-TERMINALS-3-AC008/232911702485?epid=1751258924&hash=item363a9e89d5:g:B9YAAOSwI2xbiWSD
these ones Smile
P9XX
PostPosted: Sun Oct 06, 2019 7:46 pm    Post subject: Reply with quote
darkhorse : Waterproof boots for these plugs if fitted to your car.
https://www.ebay.co.uk/itm/Bosch-Waterproof-Boot-for-3-Way-AMP-Superseal-JPT-Electrical-Wiring-Connector/140995260223?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3D64efa23b82e44492b9adf03e65b91549%26pid%3D100623%26rk%3D3%26rkt%3D6%26sd%3D130928490944%26itm%3D140995260223%26pmt%3D0%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1
https://www.ebay.co.uk/itm/High-Quality-3-Way-Pin-Waterproof-Boots-Fit-AMP-TYCO-Superseal-Connector-/132251832415?var=&hash=item647c53aada
darkhorse
PostPosted: Mon Oct 07, 2019 12:20 pm    Post subject: Reply with quote
Cheers P9XX, Ive still got good boots on the old coil connectors,also not sure if those fit the Bosch connectors..!?
As an update to this. Having spoken to Porsche OPC today the connectors are NOT available individually and it is a new loom at around a grand if you want to get them...
So, fingers crossed these are the right ones from ebay
