997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
The Porter
PostPosted: Sat Oct 05, 2019 7:58 pm    Post subject: Throttle body anti vibration rubber mount Reply with quote
So, when removing the rubber mount that attaches to the throttle body it broke in half as was broken.
I ordered the part from Porsche which has been superseded...
The old rubber mount was 10mm long and 10mm wide, the new one is 15mm wide and 15mm long which means it overhangs the aircon belt and it is too long for the bracket so you cannot screw the fixing bolt....?
Porsche are 'looking into it' as that 'is the part'...
Just wanted to ask if anyone else has experienced this on their car and how they got round it? I can't remember the old part number / new part number. Sorry.
I've also looked online and contacted suppliers for a M6 male/Male rubber mount with no luck also.
Any help greatly appreciated. Tried to add a picture but having issues doing so as I'm over 40.
The Porter
PostPosted: Sat Oct 05, 2019 8:00 pm    Post subject: Reply with quote
The car is a 2004 996 C4S, forgot to mention that part...
steve r
PostPosted: Mon Oct 07, 2019 9:23 pm    Post subject: Reply with quote
I had the same problem, theres 2 part numbers listed, item 12 in MG 1 SG 07 Illustration 107-00:
A 930 110 579 01 bonded rubber buffer and
999 703 265 00 bonded rubber mounting 20 X 15/M6
I think it was the second one that was supplied rather than the first. I did a temporary repair by glueing the old one back together and now this thread has me wondering if I ever fitted a new one.....
Question
40th Anniversary
The Porter
PostPosted: Tue Oct 08, 2019 3:02 pm    Post subject: Reply with quote
Found the problem. As my car is the last run of the 996, end of 2004 it has a 997 throttle body on it with associated screws, bolts and this part.
All sorted, if anyone needs the part number just let me know
