997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Shedman
PostPosted: Fri Oct 04, 2019 7:22 pm    Post subject: I just fitted this...... Reply with quote
After a long trip to Yorkshire and back to see the Cycling World Championships I parked the car up in its normal place but next morning when I started it the horn was stuck on.
Seeing multiple posts regarding the rubber grommets on the airbag frame I decided that was it and ordered one, mines a 97 so no risk of a new frame not fitting my wheel/airbag. Installation was a piece of cake following the steering wheel instructions on Pelican Parts.
I can drive it now without it seeming like a scene from Little Miss Sunshine.
1997 993 Targa Manual
 Filesize:  95.26 KB
 Viewed:  1887 Time(s)
Shedman
PostPosted: Fri Oct 04, 2019 7:23 pm    Post subject: Reply with quote
The eagle eyed may spot that that is the old frame and not the new one. So my subject title isn’t absolutely correct.
Albionmuz
PostPosted: Sat Oct 05, 2019 4:18 am    Post subject: Reply with quote
I have a same year Targa as yours. I noticed in your European trip thread that you arrived back with the belt sensor pulley on the way out and now the rubbers on the airbag frame too. I have had exactly the same happen on my Targa over the last year. Interesting that they should go after the same length of time. My mileage is coming up to 84k, if yours is anywhere near the same it seems we can tie these things down to age AND mileage!
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Shedman
PostPosted: Sat Oct 05, 2019 9:14 am    Post subject: Reply with quote
Hi there Albionmuz. Mine is around 86k and 1997 so all looks similar. To me on the original one the metal shafts in the middle of the rubber grommets seemed to bind on the bolt so that the rubber was twisted when originally fitting. That may be the cause. The new one didn’t to have the same issue.
This afternoon I’m going to try and replicate rain leaks above the door A pillar to see what’s going on.
Albionmuz
PostPosted: Sat Oct 05, 2019 10:07 am    Post subject: Reply with quote
Shame you are not nearer Precision Porsche, deMort is the Targa guru. He sorted my squeaks and leaks, massive difference after he worked his magic. Been leak free for a year now
993 Targa manual
Alfa GTV Twinspark
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Cameltoe & Heel
PostPosted: Mon Oct 07, 2019 2:01 pm    Post subject: Reply with quote
Yep I had the same on my 97 Targa, mine started tooting whilst on left turns, bloody embarrassing whilst out on my first drive since restoration. Mrs was laughing her head off.
I also have a leak on my roof on passenger side above the A pillar, I have details of how it's fixed using butyl behind the door seal.
Trev
