991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
Matrixxxx
PostPosted: Wed Oct 02, 2019 7:13 pm    Post subject: Cayenne 2009 GTS fault codes Reply with quote
Hi all,
just some codes that I got from my iCarsoft POR V2.0
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
GTS 2009.pdf
downloaded
Download
 Filename:  GTS 2009.pdf
 Filesize:  106.13 KB
 Downloaded:  26 Time(s)
PostPosted: Wed Oct 02, 2019 7:45 pm    Post subject: Reply with quote
Clear all fault codes .. drive for 20 miles then check what codes you have .. some might be a problem and some might be old battery related codes .. either way you need a reset and a drive to see what the car reports as a fault .
There are some i'm interested in but if they dont come back then there isn't a fault .
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Wed Oct 02, 2019 8:55 pm    Post subject: Reply with quote
This site may be useful https://www.porscheclubgb.com/PCGB/media/R31%20assets/Docs/tec_dtc_pcodes.pdf?ext=.pdf
Matrixxxx
PostPosted: Thu Oct 03, 2019 8:31 am    Post subject: Reply with quote
Ok I will reset tonight and rescan when I get home tomorrow.
Matrixxxx
PostPosted: Tue Oct 08, 2019 8:27 pm    Post subject: Reply with quote
just got some more codes
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
GTS 2009-2.pdf
Download
 Filename:  GTS 2009-2.pdf
 Filesize:  102.48 KB
 Downloaded:  16 Time(s)
PostPosted: Wed Oct 09, 2019 7:04 pm    Post subject: Reply with quote
light codes and i assume you have non standard headlights or bulbs .
A single park sensor fault .
Acc sensor , psm related .. for the cost i would tend to just replace this to see if it clears the code .. under the wheel arch liner from memory .
Might be related to the hesitation .. im dubious atm but replace it and see .
Matrixxxx
PostPosted: Thu Oct 10, 2019 10:40 am    Post subject: Reply with quote
just ordered a new acceleration sensor £180.00 Sad
Matrixxxx
PostPosted: Sun Oct 13, 2019 9:28 pm    Post subject: Reply with quote
Fitted new sensor and wow what a difference, I now float along, the suspension must have been malfunctioning , and no more chassis fault.
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
SD99
PostPosted: Sun Oct 13, 2019 9:37 pm    Post subject: Reply with quote
Nice work
