997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
wibbaboo
2003 Porsche 996 Carrera 2
PostPosted: Wed Oct 02, 2019 12:25 pm    Post subject: Battery Replacement - Help Reply with quote
Hi All,
Although I've been using a trickle charger - I went to take out my 996.2 today to find a completely dead battery - On reconnecting the trickle charger and pushing the connection hard into the cig lighter it started to charge and I got at least a glimmer of power to the console.
I've left on charge and started a web search for batteries.
Europarts have a 50% sale on - but I'm confused as to the exact battery to buy!!
Can someone point me at a recommended make and model please
Ta
Greg
pugw$sh
PostPosted: Wed Oct 02, 2019 3:57 pm    Post subject: Reply with quote
This is the one I bought for my 1999 996 C2
https://www.eurocarparts.com/p/lion-100-car-battery-70ah-3-year-guarantee-444771001
Coming in at £50 with discount code PAYDAY50
I've had no problems with it for over 2 ½ years.
Number21
PostPosted: Wed Oct 02, 2019 9:27 pm    Post subject: Reply with quote
Most people seem to rate the Bosch S5. My car (996.2) had one put in in 2016 and it died a few months ago.
I managed to resuscitate it but eventually gave up and just got a Halfords battery in a hurry. It's been fine. I can now leave the car a week without worrying about not even being able to pop the frunk (don't have a garage, trickle charging isn't possible).
cvega
PostPosted: Thu Oct 03, 2019 9:29 am    Post subject: Reply with quote
I've heard around the grapevine that bosch batteries have gone down in quality - not sure what are those rumours based on.
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
maldren
PostPosted: Thu Oct 03, 2019 11:32 am    Post subject: Reply with quote
Internet rumours!!!!
Mike
911-C2
PostPosted: Thu Oct 03, 2019 12:46 pm    Post subject: Reply with quote
I have been very happy with the below, car was left a couple of weeks and fired up no problem. Definitely an improvement on the old battery.
https://www.tayna.co.uk/car-batteries/bosch/s5010/
Panda996
PostPosted: Thu Oct 03, 2019 1:05 pm    Post subject: Reply with quote
I also used Tanya to order. It’s a good next day delivery service.
I chose the Varta Silver. As heard it was made in same factory and same standard as the Bosch, but was quite a bit cheaper. It’s been fine for approx 5 years, although like everyone else, it needs constant trickle charge as car has never coped with 2 weeks unattended (even from nearly new... damn tracker I suspect!)
996 Targa
wibbaboo
PostPosted: Thu Oct 03, 2019 4:06 pm    Post subject: Reply with quote
Thanks all for your help
https://www.tayna.co.uk/car-batteries/exide/eb802/?gclid=Cj0KCQjwuNbsBRC-ARIsAAzITudLK2Y4zRzl6qx113jhVqOr_ELUbgFlpgQz70cZd1Gt5usoIplZxMYaAmVkEALw_wcB
Was an exact replacement for what was previously fitted (and that lasted from April 2012) so I went with the same Smile
P.S. No-one told me about the alarm going off when you disconnect the battery - 2 min search on here gave me the answer to put the key in the ignition and turn on without starting the car.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Nov 20, 2019 4:34 pm    Post subject: Reply with quote
Supplementary question:
Do I have to disconnect the battery to fit a new light switch to my 4S?
Assuming I do...
- if I leave the ignition in the 'on' position then the alarm won't go off when I disconnect/reconnect the battery?
- do I have to start the car and leave it idle for a bit to let the electronic throttle recalibrate... anything else I need to do to force it to recalibrate?
- do I have to reset the windows?
PostPosted: Wed Nov 20, 2019 5:01 pm    Post subject: Reply with quote
Carparts4less are cheaper than ECP and its the same company.
Magic919
PostPosted: Wed Nov 20, 2019 5:09 pm    Post subject: Reply with quote
Probably safer to disconnect, but hardly essential if you are sensible.
The windows might need to relearn and a few other things need a short drive.
997.2 C4S PDK
PostPosted: Wed Nov 20, 2019 8:12 pm    Post subject: Reply with quote
Assuming I do...
In short then no.
with a battery disconnect on this model ...
Ign turned on ( lights illuminated ) .. disconnect battery ..
Disconnect Neg lead then positive if replacing .. never disconnect the positive first .
Only Neg lead for something like this .
pos lead on first then neg lead .. basically never touch the positive lead with a spanner when the neg lead is still connected .
Close each window ..doors shut then press and hold the up window button for 5 seconds .. that will relearn the one touch close .
radio code if applicable .
ignition on and don't touch the throttle pedal for 30 seconds .. ignition off then drive as normal .. car will learn without this though so no big deal .
Steering angle sensor will reset after a drive over 6 mph but that's more for 997 than these .
Robertb
PostPosted: Wed Nov 20, 2019 9:52 pm    Post subject: Reply with quote
Thanks DeMort for the comprehensive answer as always Thumb
