997 : 2004- 65
Cayman : 2005- 22
Macan : 2014- 8
mactrack
PostPosted: Sat Sep 28, 2019 9:17 pm    Post subject: 4 x Goodyear Eagle F1 Asymmetric 2 Tyres N0 265/235/35/20 Reply with quote
This set of 4 tyres were taken off a Cayman which had done just 8,672 miles from new. The fronts are 235/35/20 Y88 and rears 265/35/20 Y95. They are Porsche "N" rated. The tread depth was measured on 15 July 2019 when the car was serviced and the mileage was 7,442 and are as follows;
Front Left
Outer 6.0mm
Middle 6.5mm
Inner 6.5mm
Front Right
Outer 6.2mm
Middle 6.3mm
Inner 6.5mm
Rear Left
Outer 5.5mm
Middle 5.5mm
Inner 5.7mm
Rear Right
Outer 6.5mm
Middle 6.7mm
Inner 7.0mm
Price is £250 and they can be viewed/collected from Bromley SE London/NW Kent. Thanks
mactrack
PostPosted: Thu Oct 03, 2019 6:52 am    Post subject: Reply with quote
Price reduced to £199.
mactrack
PostPosted: Wed Oct 16, 2019 4:38 pm    Post subject: Reply with quote
Price reduced to £175.
fildyke
PostPosted: Wed Oct 16, 2019 5:08 pm    Post subject: Reply with quote
Hi.
What date stamp are they.
mactrack
PostPosted: Wed Oct 16, 2019 5:39 pm    Post subject: Reply with quote
The front 235/35's are both 10/15. One rear 265/35 is 13/15 whereas the other is 17/17. Presumably the latter was replaced by the previous owner due to a puncture or suchlike.
mactrack
PostPosted: Tue Oct 22, 2019 12:02 pm    Post subject: Reply with quote
Last try at £149.
mactrack
PostPosted: Wed Oct 30, 2019 1:58 pm    Post subject: Reply with quote
Rear 265/35/20 set are OHPF. Front 235/35/20 set now available at £75.
