997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
Milly
PostPosted: Sun Sep 22, 2019 4:20 pm    Post subject: Reinforcement Reply with quote
Hi, I have bought what Porsche call a 'reinforcement', part no.99351277700. It is meant to strengthen the spoiler to stop the plastic bending out of line with the engine lid, as it does after time due to the heat. It is a turbo part but can also be used on cars from 1997 apparently - why not all 993's I do not know.
I need help with installing it. I think it simply fits into a gutter in the spoiler underneath and I assume it will need to be glued in place once the excessively curved spoiler is straightened - am I right? and if so what would be the best adhesive to use?
You can tell I am running out of things to do!
wilsonny
PostPosted: Sun Sep 22, 2019 7:24 pm    Post subject: Re: Reinforcement Reply with quote
yep, narrow u shaped bar, works a treat when glued in. there's a write up on here somewhere, but basically get your spoiler off, roughen the ridge where it fits, glue it in and clamp the spoiler straight while the glue dries. I used this glue...
U-Pol BLACK Tiger Seal PU Adhesive Sealant Tigerseal Bond Body Panels UPOL Sealer Single 310mm Chaulk Cartridges https://www.amazon.co.uk/dp/B01AAN6LC2/ref=cm_sw_r_cp_apa_i_0L8HDbK0EGA76
1996 C2 manual
PostPosted: Sun Sep 22, 2019 8:02 pm    Post subject: Reply with quote
Some more info here....
http://911uk.com/viewtopic.php?p=953527
Milly
PostPosted: Sun Sep 22, 2019 8:56 pm    Post subject: Reply with quote
Thanks a lot Jonttt / wilsonny - all the info I need - just have to get the adhesive now.
