So this winter I plan to recommission the A/C on my car, including replacing the evaporator and condensor, so wondered if anyone had tackled this recently and had any tips to share ?
My plan of attack is based on using these guides:
https://www.pelicanparts.com/techar...eplacement/65-ELEC-Evaporator_Replacement.htm
https://www.pelicanparts.com/techar...ase_Removal/63-ELEC-HVAC_Suitcase_Removal.htm
https://www.pelicanparts.com/techar...ement/64-ELEC-Expansion_Valve_Replacement.htm
I'm also going to remove the front Pu at the same time, to make changing the condenser easier and "while I'm in there" change out the oil cooler temp sensor and the corroded headlight guides.
The CCU unit is off to Bergville to get serviced and I've got a new compressor, dryer and the a/c lines have been changed.
I've got an hydraulic lift, which should make the whole job that bit "easier".
So any expeience to share and any other jobs I should add to my list that go in with this work ?
