997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
NotoriousREV
PostPosted: Fri Sep 20, 2019 6:48 pm    Post subject: Clocks lit up? Reply with quote
My wife just went out to her car to get something and she noticed that my
clocks were displaying the mileage/speed/clock etc. I haven’t used the car at all today and I’m 100% sure it wasn’t lit when I walked passed it earlier this afternoon. I checked it was locked, unlocked it and tried locking it again but they stayed lit up. I tried to start the car but the battery was too drained. I’ve taken the battery off and put it to charge (it was down to 10v).
Any ideas what’s caused this?
PostPosted: Fri Sep 20, 2019 6:51 pm    Post subject: Reply with quote
Low battery voltage.
NotoriousREV
PostPosted: Fri Sep 20, 2019 6:53 pm    Post subject: Reply with quote
Is it one of those things were it goes a bit nuts when the volts drop?
PostPosted: Fri Sep 20, 2019 8:29 pm    Post subject: Reply with quote
Most likely.
cvega
PostPosted: Fri Sep 20, 2019 10:06 pm    Post subject: Reply with quote
Alarm should go off too when it drops too low. Very amusing at 2am.
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
PostPosted: Sun Sep 22, 2019 6:56 pm    Post subject: Reply with quote
A guess would be a faulty ignition switch or a faulty instrument cluster with ign switch being the most obvious out of the two .
It's just about possible it's the light switch but i would expect the side lights to be on as well .
Disconnect light switch to check and then disconnect ignition switch to see if either turns them off is what i would do .
These light on all the time will flatten a battery in a day or two of it being unused .
Indy Mechanic .
NotoriousREV
PostPosted: Fri Jan 31, 2020 2:51 pm    Post subject: Reply with quote
So this problem has cropped up again. My battery is brand new and fully charged, I’ve fitted a new ignition switch but the odo/speedo/clock stay permanently lit. Any ideas?
PostPosted: Fri Jan 31, 2020 8:52 pm    Post subject: Reply with quote
I will have to suggest a garage looks at this .. a live dash will flatten a battery in a few days .
My feeling is a cluster fault but there's no checks or indeed anything i can think of to help out here .. sorry .
Indy Mechanic .
NotoriousREV
PostPosted: Sat Feb 01, 2020 12:35 pm    Post subject: Reply with quote
Cheers. I’ll get it into my trusted Indy.
911Tip
PostPosted: Sat Feb 08, 2020 8:50 pm    Post subject: Reply with quote
Happened on mine, and was the ignition switch as mentioned above. VAG part sorted it out.
