997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayman : 2005- 20
Cayenne : 2003- 7
DAVIDGT996
PostPosted: Thu Sep 19, 2019 11:58 am    Post subject: Ticking noise to Rebuild time - worst 50 Miles ever. Reply with quote
Well my ticking noise that developed after doing an oil change was diagnosed as a big end bearing failure. Not sure if if the oil change bringing down some sludge and blocking the oil ways had anything to do with this but I only did about 50 miles after the oil change when I noticed the ticking noise on idling on my driveway.
Its rebuild time for me I'm afraid which was originally planned for 2 years time once I had finished paying University fees for my youngest.
The history on this car was a bit sketchy when I bought it so I knew a rebuild was on the cards at some stage with 100K on the clock. The service book said the IMS bearing had been changed at 80K so I was not to worried about that going pop on me.
The engine has been dropped and broken and it has come to light at some stage the engine has been broken before as it has closed deck liners installed. I have also been told that I have bore score on 4 & 5. Photos have been supplied etc.
There is no play in the IMS bearing which is the standard OEM bearing fitted by Porsche Sussex, however, as part of the rebuild I am advised to have this replaced. I have been given various options here with one of the options being replaced FOC with another standard OEM bearing. What would you go for here and would the extra £500 ish for the EPS bearing really be worth the extra money?
2001 C2 Coupe Tip
Black, GT3 kit, lowered
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Sep 19, 2019 1:03 pm    Post subject: Reply with quote
That is seriously bad luck. Sorry. How do the other bearings look? I'd go with a standard IMSB minus seals. What is your thinkung WRT the bore scoring? I don't see how an oil change could affect it.
DAVIDGT996
PostPosted: Thu Sep 19, 2019 1:14 pm    Post subject: Bearings Reply with quote
the other bearings looked OK - they will all be replaced but having to go with a secondhand crank as cant be reground within tolerances.
3-6 will be lined - doesn't make sense just to do 4 & 5.
2001 C2 Coupe Tip
MisterCorn
PostPosted: Thu Sep 19, 2019 1:26 pm    Post subject: Reply with quote
Have you sourced a secondhand crank? Is it a 3.4 or a 3.6? Both are like hen's teeth though due to not being regrindable. I keep an eye on the usual sales places and have bought one of each in the last 3 or so years for a sensible price.
DAVIDGT996
PostPosted: Thu Sep 19, 2019 1:30 pm    Post subject: s/h crank- 3.4 Reply with quote
yes my man has sourced one - he's into racing on the Porsche Motorsport circuit and found one at one of his specialist contacts.
2001 C2 Coupe Tip
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Sep 19, 2019 1:53 pm    Post subject: Reply with quote
Closed deck rebuild? Any idea who did the work?
DAVIDGT996
PostPosted: Thu Sep 19, 2019 2:09 pm    Post subject: Reply with quote
yes - a well known engine rebuilder which I am not going to mention on here at the moment until I found out more.
2001 C2 Coupe Tip
C4Silver
PostPosted: Thu Sep 19, 2019 2:14 pm    Post subject: Reply with quote
Can we guess ?? Draw straws ??
DAVIDGT996
PostPosted: Thu Sep 19, 2019 2:17 pm    Post subject: Reply with quote
not sure if they were done previously on 1-3 and left 3-6 alone? I will find out more and report back.
2001 C2 Coupe Tip
MisterCorn
PostPosted: Thu Sep 19, 2019 2:21 pm    Post subject: Reply with quote
I think it is largely irrelevant who did the previous work, unless it is thought that the failure was caused by some debris they left in. I'd be interested to see photos of the bearings though. We know that they wear and around 100k can be rebuild territory depending on usage patterns.
DAVIDGT996
PostPosted: Thu Sep 19, 2019 2:27 pm    Post subject: Bearings Reply with quote
failed bearing
2001 C2 Coupe Tip
 Filesize:  870.35 KB
 Viewed:  3330 Time(s)
MisterCorn
PostPosted: Thu Sep 19, 2019 2:32 pm    Post subject: Reply with quote
It is the others I was more interested in to see how close they were. Are there date codes on the shells to see if they have been changed previously?
DAVIDGT996
PostPosted: Thu Sep 19, 2019 3:34 pm    Post subject: Reply with quote
all 6 were done previously.
Before anyone jumps to conclusions they are not the Aluminum Nikosil liners used by a well know engine re-builders prominent on here. I have spoken to them and shown them the photos.
2001 C2 Coupe Tip
GMG
PostPosted: Thu Sep 19, 2019 4:19 pm    Post subject: Reply with quote
...I had Westwood steel liners installed when my engine was rebuilt as hairline cracks were discovered when the block was tested...a very well established (100yrs) engineering company fitted them...all good with me...
DAVIDGT996
PostPosted: Thu Sep 19, 2019 4:34 pm    Post subject: Reply with quote
Westwood was mentioned for replacement liners but he is recommending liners made from an engineering firm that makes them for classic F1 cars & Ferraris.
2001 C2 Coupe Tip
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Sep 20, 2019 2:06 am    Post subject: Reply with quote
As for the IMS bearing, go for the original again with seals removed, I've done this whenever I've had the engine apart. Or have the block machined to accept the later, larger bearing.
Marky911
PostPosted: Fri Sep 20, 2019 4:48 am    Post subject: Reply with quote
Nightmare.
Bad luck especially since the engine has already been rebuilt once.
Your guy is probably talking about liners by Capricorn then?
DAVIDGT996
PostPosted: Fri Sep 20, 2019 7:20 am    Post subject: Reply with quote
I was interested to find out which make/version of liners had failed so the same ones didn't go back in. On further research there is now some confusion on whether it was strengthening work on the bores. Not quite sure what strengthen work means in relation too closed deck design?. Anybody care to enlighten me.
2001 C2 Coupe Tip
Marky911
PostPosted: Fri Sep 20, 2019 7:42 am    Post subject: Reply with quote
Probably support rings. If the bores were still within tolerance for roundness then support rings around the top of the bores would have been an option. They aim to stop ovality at a later date.
Not as thorough a solution as re-sleeving. Cheaper though.
DAVIDGT996
PostPosted: Fri Sep 20, 2019 7:50 am    Post subject: Reply with quote
thanks- that makes sense as there is slightly different metal colouring at the top of bores 4&5.
2001 C2 Coupe Tip
Goto page 1, 2, 3  Next
Page 1 of 3
