997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayenne : 2003- 7
PostPosted: Sun Sep 15, 2019 4:26 pm    Post subject: Cayenne Transfer Box Failure Reply with quote
We have started to see several of these recently , this is a 2012 model .
Kinda figured we might as well have a look inside and see what's going on and i'm sure there will be someone on the forum that likes to see things in bits Very Happy
Various images of it apart and then partially stripped.
New clutch pack , in depth cleaning of parts then a forced regen to recalibrate the control unit / motor seems to have fixed this one .
Right click any image and select view in new tab ( chrome ) for a larger picture .
Indy Mechanic .
 Filesize:  718.62 KB
 Viewed:  1534 Time(s)
 Filesize:  765.64 KB
 Viewed:  1556 Time(s)
 Filesize:  741.45 KB
 Filesize:  808.71 KB
 Filesize:  754.92 KB
 Filesize:  790.63 KB
 Filesize:  815.21 KB
baldguy
PostPosted: Sun Sep 15, 2019 8:08 pm    Post subject: Reply with quote
Had mine done at 42k miles last year... disgusting that these let go even at this mileage... it has full OPC history...
958 Cayenne Turbo - Amethyst
996 Carrera 4 - Lapis
G430 Sport
Pops
PostPosted: Mon Sep 16, 2019 3:45 pm    Post subject: Reply with quote
Interesting post Iain, thanks for the pictures and it is good to hear that you can repair these rather than replace!
What was the mileage of that vehicle and the condition of the transfer fluid which you drained?
2013 Porsche Cayenne 4.2 S Diesel (958).
Remapped by Celtic Tuning.
911TEL
2011 Porsche 997 Turbo S
PostPosted: Mon Sep 16, 2019 4:48 pm    Post subject: Reply with quote
This is quite a common failure .....Mine was changed at 30000 on my 2015 958......
I was told it’s a design fault of a badly routed breather pipe which allows water ingress in certain conditions ...
Mine was carried out under warranty but if not it’s a 4.5k job if it’s an OPC replacement....worrying costs but a good reason to keep the warranty going ...it may not be the only time it gets changed ...
I suspect it’s also due to uneven wear on tyres back to front re the rolling circumferences and the transfer box is the unit that synchronises the front / rear drive split ?
I’m prepared to see mine changed again ..
There are stories of vehicles in the US of A having 4 or 5 changes in the life of a Vehicle!
Frightening on a Porsche .....
997 Gen 2 Turbo S Basalt Black -Now ..at 911Virgin looking for a new Owner
SL 55 AMG Obsidian Black
Brompton S2L Black edition
PostPosted: Mon Sep 16, 2019 7:51 pm    Post subject: Reply with quote
This car had done approx 60K miles ..
It had a modified breather which was a problem on cars without this .. water ingress and oil don't mix well .
Circa £1500 - £2K for the above .. diagnosis of this fault isn't easy .. it feels similar to an engine running fault .
This seems to be more of a fault on the later cayennes than the earlier ones .
Incorrect tyres will have a significant impact on damage to diff / transfer box on a cayenne than a sports car ... no transfer box but you get what i mean .
N rated tyres .. must be the same per axle .
Oil was no where near due a change and was fine .
Indy Mechanic .
EGTE
PostPosted: Mon Dec 30, 2019 10:41 am    Post subject: Reply with quote
This is becoming yet another Porsche engineering plague.
Transfer box oils need replacing every 20K at most.
easternjets
Watkins Glen
PostPosted: Mon Dec 30, 2019 12:27 pm    Post subject: Reply with quote
I've got a V6 TDi Touareg and after reading this I got a bit worried as my car has done 45k miles and never had the box fluid changed. My car went in for a service and also needed a replacement drivers side door wiring loom.
I asked if I could have the fluid in the box changed and I was told that the oil is good for the lifetime of the car but I told them I wanted it done regardless.
At first they couldn't get the oil so I bought some off fleabay that was genuine VW and they changed it for me and included it in the service.
I can't see why they can't just change it as part of a major service, the oil is only £30 and it takes minutes to do if you've got the underside stripped.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
PostPosted: Mon Dec 30, 2019 6:22 pm    Post subject: Reply with quote
It depends to a degree which type of transfer box you have fitted .. this is more the " clever " type that seems to be affected although i have seen gen 1 boxes fail..
Different symptoms though .
With this type fitted then with a tester you can see the wear life of the oil and wear ( calculated as i understand it ) to the clutch pack and oil.
This check should be done with a tester on a service .
The unusual point is that none of the ones i've seen , only a few , have reached the interval that an oil change is warranted .
I can also say that a calibration done when the box is already showing driving faults does not work.
The one we have in atm .. the box is not a viable repair as it needs all bearings , clutch , chain and unfortunately one of the bearings has spun in the casing .. possible to repair but with the added items it's not realistic .
Indy Mechanic .
Porkaholic
PostPosted: Mon Dec 30, 2019 6:37 pm    Post subject: Reply with quote
Bit worrying if it the oil is fine, already has a breather pipe fitted and still getting failures. Inclined to keep warranty going, mine went after only about
14,000 miles and I've never used it for towing, ploughing or offroading!
Would be interesting to know the failure rate as a percentage so you can take a more balanced view of the risk.
2009 997.2 4S manual cab, light mods
2017 Cayenne S
2015 Mini
Volvo 460 GLT (Rally toy, 'The Meatball')
PostPosted: Mon Dec 30, 2019 7:01 pm    Post subject: Reply with quote
well .. i posted this as a thread were people could see what these look like in bits and to point out we have started to see them as being a possible problem ..
What for me is a lot is not so in the real world i guess ..
Never seen a problem before but 4 in less than 6 months had me thinking i'd mention it .
More so due to the fact you can check the degradation on a tester and none of these should have had a fault or needed an oil change .
I can't say the reason for the failure , logically a calibration should fix this fault .. but it doesn't .
In short i have limited info so all i can suggest is change the oil early on these .
If you have the full off road package then the car is horrendous to drive when the transfer box starts messing about .. scared the crap out of me i can tell you !
I point out what i see .. i leave it upto you lot to make what you want out of the info Smile
An oil change without telling the car its been done strikes me as the way forward .. but i'm afraid i can't condone that .. it's just a hunch .
Indy Mechanic .
