991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
HMC911T
PostPosted: Thu Sep 12, 2019 7:22 am    Post subject: POOR PERFORMANCE : ( Reply with quote
Hi
People
Looking for any ideas here ?
I have an 02 996 turbo stock 93k full porsche service history with eismann exhaust sports cat
I had taken it in for a stage 1 remap I recieved a call stating that I had a boost leak.
The remap place recommended another garage to fix the problem turns out one of the pipes had been bodged before so they said replace
£820 later.
Just had my car remapped again and it only made a 2 hp gain with the new boost pipe fitted.
So the results from the remap are 438 BHP and 650 n/m torque
They said the torque was as expected but obviously the hp is down
Has any body experienced this any ideas what it could be ??
Are the turbos going out??
Not sure any help would be greatly appreciated!
cheshire911
Estoril
PostPosted: Thu Sep 12, 2019 8:09 am    Post subject: Reply with quote
I'd suggest that you speak to Wayne at Chip Wizard (look him up on the web).
996 2002 X50 Turbo Manual
PostPosted: Thu Sep 12, 2019 4:18 pm    Post subject: Reply with quote
I would first txt Wayne as he doesn't answer his phone while he's working due to background noise , he is the best of the best with mapping Thumb
https://chipwizards.co.uk
ragpicker
Reims
PostPosted: Thu Sep 12, 2019 4:57 pm    Post subject: Reply with quote
As above.
If only there was a well modified turbo for sale with a bulleproof, rebuilt engine Question
http://911uk.com/viewtopic.php?t=131025&highlight=
Then there wouldn't be any problems with performance....
(sorry for the shameless plug)
not sorry
996 turbo - FOR SALE, Price reduced: http://911uk.com/viewtopic.php?t=131025&highlight=
NedHan79
PostPosted: Thu Sep 12, 2019 5:39 pm    Post subject: Reply with quote
Who did the mapping? What boost pressures are set? Was it live mapped on a dyno or on the road? Did you get any sort of graphs to back up results?
There are a world of questions. I’m not a mapper and I’m definitely not an expert but I have been through the mill tuning other turbo cars to various levels. One thing is people always expect figures far higher than realistic though your hp result sounds poor. Low down torque would be the big player in a mapped performance car and I would expect spool and torque should be excellent in a twin turbo car as 2 small turbos are obviously sharper than one large.
How does the car feel?
#modified996mk1
HMC911T
PostPosted: Thu Sep 12, 2019 7:00 pm    Post subject: Reply with quote
Thanks guys I'll message him
The car seems spot on it pulls well enough no flat spot pulls lovely through the rev range I'm just concerned to why the horse power is that low ?
I'm hoping it's not a serious problem ?
PostPosted: Thu Sep 12, 2019 8:00 pm    Post subject: Reply with quote
I don't normally answer any post on modding / mapping as its well out of my comfort zone .. i'm afraid i fix standard porsches .. i tend to get stuck with faults with modded cars.
What i will say .. first check is any fault codes stored in the dme ..
Second check .. what are the fuel adaptions saying for idle , mid and high range rpm .
The figure of 438 BHP .. i'm assuming that's flat out .. balls to the wall with no Lambda adaptations .. the car just dumps as much fuel as it can ..
Well .. is there enough fuel when flat out Question
A fuel pump that's 17 years old might not deliver the amount required .. seen a few on this forum where fuel pumps have been at fault .. its also an item that i tend to say these days its best to replace even if you don't have a problem . old and tired basically .
Nothing to say its not turbos but at the end of the day that's just a fan spinning at high rpm and chucking as much air into the engine that it can .. its either works or it doesn't as a rule of thumb .. i know that's simplistic but for arguments sake ..
If not enough fuel then it will be down on power at max rpm .
Just my thoughts anyways and as i said .. a wee bit out of my comfort zone .
ok51mon
PostPosted: Thu Sep 12, 2019 8:57 pm    Post subject: Re: POOR PERFORMANCE : ( Reply with quote
HMC911T wrote:
Hi
People
£820 later.
Your car is still leaking. DM me we can talk it out on the phone.
4.1L Incoming
ok51mon
PostPosted: Thu Sep 12, 2019 8:59 pm    Post subject: Reply with quote
ragpicker wrote:
As above.
x
not sorry
The engine is only bulletproof if it comes with warranty Hand
4.1L Incoming
Osh
PostPosted: Fri Sep 13, 2019 3:14 pm    Post subject: Reply with quote
ragpicker wrote:
As above.
not sorry
Raggy - any idea where I might buy such a car...??
Osh
Jay.
PostPosted: Sat Sep 14, 2019 3:48 pm    Post subject: Reply with quote
Good to hear that Wayne has a great reputation here.
What are you going to on the boost read out? e.g. 0.7, 1.0, 1.1, 1.2?
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
EddieCRX
PostPosted: Wed Sep 18, 2019 2:35 pm    Post subject: Reply with quote
Was the power at the wheels?
438WHP calculates to just over 500 HP (Crank)
jerzybondov
PostPosted: Wed Sep 18, 2019 3:03 pm    Post subject: Reply with quote
Yep 438 - if it is at the wheels - sounds pretty healthy to me!
