991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
hermes
PostPosted: Mon Sep 09, 2019 10:46 am    Post subject: Stuck brake bleed nipples Reply with quote
Over the winter I’m going to remove the calipers to replace hard lines and hoses to the brakes. Ahead of that I’ve been cleaning and soaking the bleed nipples as I know they’re not in great shape.
On the weekend I checked, and I have 6 out of 8 that are stuck.
So, any recommendations on where to send the calipers to get the bleeders removed? I really want to avoid anywhere that’s going to need me to fit inserts.
RPM look after the car so I could try them, but wonder if there are better brake specialists to use.
maldren
PostPosted: Mon Sep 09, 2019 1:44 pm    Post subject: Reply with quote
Being stuck is tricky to determine, the only way you'll really know is if they break before they come out!
You must use a socket and 'T' bar so that you don't apply any bending force as you try to turn them. I did contemplate trying my 18V impact driver but luckily mine gave in to the socket set in the end (after soaking overnight with Plus Gas).
Afterwards fit stainless nipples.
Mike
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Sep 09, 2019 2:58 pm    Post subject: Reply with quote
I sent mine to pro calipers, this was after I had one break and I tried everything to get it out, including an easy out that broke in it, a caliper specialist will have more luck with them as they will have the correct technique and as said use stainless afterwards.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Sep 09, 2019 4:08 pm    Post subject: Reply with quote
tap them with a hammer
heat them with whatever you have
use the T handle on a good fitting socket to properly apply rotational force
I did this on mine and they all came out, apart from the one the PO snapped.
I removed that caliper and took it to a local engineers, they mounted it in the mill and accurately drilled it out and cleaned up the thread and cut a new nipple seat.
Didn't cost much.
MR997
PostPosted: Tue Sep 10, 2019 12:15 pm    Post subject: Reply with quote
What thread are the bleed nipples?
hermes
PostPosted: Tue Sep 10, 2019 2:38 pm    Post subject: Reply with quote
Threads are M10x1.0. I’ve had no luck with t handle hex, brake line spanner, tapping with various tools, blocking the bleed hole with a drill bit to reduce the chances of shearing, and I even tried heat on one.
I have stainless replacements ready to go back in.
Pro calipers we’re on my list of possibles, so I’ll give them a call.
Many thanks.
Ripfer
PostPosted: Wed Sep 18, 2019 8:13 pm    Post subject: Reply with quote
i have just compleated swaping mine. i found a video on utube using a glowplug removal windy gun at a low setting. approx 20Nm my version was a 18v dewalt impact driver with 3 settings and a impact socket modded to bear on the nipple hex not drop down to the caliper. this and a 15 sec squart of artic freeze spray no probs.
with just the tbar felt as if they would shear off and i did try with just the spay and it did move but the impact really is the ticket.
hermes
PostPosted: Thu Sep 19, 2019 4:57 am    Post subject: Reply with quote
Interesting info thanks. I don't know much about impact wrenches, but I'd assumed they'd just strip the top right off.
When you say you had to mod the hex socket, in what way?
Ripfer
PostPosted: Thu Sep 19, 2019 5:14 pm    Post subject: Reply with quote
a small length of 10mm? steel tube in the 11mm socket so the hammer action is on the hex
