Cayenne 957 wheel bolts in black?
SD99
27 May 2018
51
Were these ever available from Porsche or is there a good aftermarket supplier?
Assume the bolts are the same across all the 955/957`s, eg 28mm threaded shaft.
Have 25mm spacers on the rear currently which i`m planning on removing so thought it was a good excuse to get a shiny new full set 8)
I would humbly suggest you phone an opc and ask them .. i think they are available in black but im unsure .. also if spacers fitted they can tell you the correct part numbers which you can use should you wish to buy elsewhere .
25mm spacers is above what i think Porsche supply so your into aftermarket items if that's the case .
Thanks.
In the end I found a new set of factory bolts and lockers for half the price so replaced the rusty ones with those.
Spacers now removed.
124,589
1,441,831
49,019
andrew bulloch7
