991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Steve Wright
PostPosted: Sun Sep 08, 2019 5:02 pm    Post subject: Fuel gauge Reply with quote
I was low on fuel the other day and had to stop at supermarket so just put 20quid in , now I have had it before on a previous car where the gauge doesn't move so that's ok . Any way put 40 quid of shell in the same day and the gauge slowly went upto half. Ive used it a few days fine and the gauge is now showing quarter but the engine cut out just before I got home. So I'm wondering if it's low on fuel and the needle isn't acting correctly going the other way. Is this a fault any one else has seen.
PostPosted: Sun Sep 08, 2019 6:06 pm    Post subject: Reply with quote
How many miles have you done on a half tank of fuel ?
If the best part of 200 and its reading a quarter full and wont start then i would assume the gauge has stuck .. many pipes in the tank it can catch on.
I'm assuming about 400 miles per tank full for this .
Also yes to your question ... i have seen it before .
C4 or any saddle tank and if you don't put enough fuel in when empty then it will stay at empty as its a calculated value below about 1 third of a tank ...
In short it needs to have the fuel lvl above 1/3 for it to be able to see and register a value .
Put what car you have in a signature please Smile
